detroit locker possible ?
Old Feb 25, 2012 | 05:00 PM
coreytat's Avatar
coreytat
Default detroit locker possible ?
I have been playing with the idea of a detroit locker in the rear of the sc they sell a toyota style carrier in 7.5 (23 spline) 8" (30 spline) 8.875" (30 spline - 19 spline) ive been researching and wondering if anyone has played with this wierd idea they are only 479 compared to the price of lsd and alot more reliable any input positive or neg please
Old Feb 25, 2012 | 05:53 PM
coreytat's Avatar
coreytat
Fits small hub bearing 45mm. 1.30 in. axle shaft diameter
Old Feb 25, 2012 | 11:01 PM
INTIMAZY's Avatar
INTIMAZY
Interesting idea.... terrible for handling but a solid option for drag guys..
Old Feb 26, 2012 | 12:49 AM
scott101's Avatar
scott101
I know some people use them draging and some old work trucks have them. seems like a good alternative to welding, seems like it would be more reliable. If you end up doing it, please post it up because Im thinking of welding the oem open and if you have success with the locker diff I might go that route
Old Feb 26, 2012 | 11:14 AM
coreytat's Avatar
coreytat
it wouldnt be nearly as bad handling wise as a welded they disengage automaticlly on turns as long as you stay off the gas in the turns as soon as youn get on the pedal its 100% torque to both wheels if the nascar **** can turn at high speed with them why not try
Old Feb 26, 2012 | 11:15 AM
coreytat's Avatar
coreytat
does anyone have the diff specs
Old Feb 26, 2012 | 01:22 PM
INTIMAZY's Avatar
INTIMAZY
I agree. Wayyy better than welded.
For street use I think this would be a very good idea.
Old Feb 26, 2012 | 06:16 PM
coreytat's Avatar
coreytat
if anyone knows how many spline is on the side shaft gear would be a great help on which would be the base to order off of
Old Feb 28, 2012 | 05:25 PM
coreytat's Avatar
coreytat
bump for help
Old Feb 29, 2012 | 02:53 PM
souljah798's Avatar
souljah798
This is interesting, hope you make some progress. It would be a great alternative.
Old Mar 1, 2012 | 05:06 AM
bodydrager's Avatar
bodydrager
Totally incorrect! A locker does exactly as it says, it locks the differential. A locker doesn't disengage on turns it is just like running a welded diff. A LSD disengaeges.
Old Mar 1, 2012 | 05:18 AM
MDSC's Avatar
MDSC
youre wrong, a spool is whats stays locked at all times detroit locker is an old locking diff technology its strong but very loud when it engages and disangages.
Old Mar 1, 2012 | 06:01 AM
shima's Avatar
shima
I have a locker in my 4x4 and although very handy for traction i would not like one in my soarer. Turning into tight corners i.e parking spaces is a nightmare. Nice when it unlocks and you get the clicking but the moment it locks you know. My diff also Sheds a lot of metal filings after a lot of use. IMO lockers should only really be used in 4x4's spools for drag and LSD for everything else. Could you not source a LSD from a crashed Supra?
Old Mar 1, 2012 | 06:18 AM
INTIMAZY's Avatar
INTIMAZY
Truth.
It does disengage on turns. How effectively it does it is debatable but it does not remain fully locked. They don't sound pretty but they work.
Old Mar 1, 2012 | 10:33 AM
bodydrager's Avatar
bodydrager
This is news to me. I have a detroit locker in my wrangler on a 1 ton GM 14 bolt. It never disengages in turns.
