GTE block rebuild piston ring gap help.
Old Feb 22, 2012 | 07:26 PM
phamxOC's Avatar
phamxOC
Default GTE block rebuild piston ring gap help.
just got my block back from the machine shop. im gonna be running stardard size ring and aiming to make 400-450hp. what do u guys gap your rings at? RING #1 , #2, and #3.
Old Feb 22, 2012 | 07:29 PM
phamxOC's Avatar
phamxOC
internals are stock and cleaned up, just clevite high performance bearings
Old Feb 22, 2012 | 11:29 PM
phamxOC's Avatar
phamxOC
anybody?????
Old Feb 23, 2012 | 03:59 AM
spoolxexo's Avatar
spoolxexo
I always use OEM specs on the 1st and 3rd ring.
On the 2nd ring, I like to go .002" tighter. This helps with the sealing under vacuum.
If you use Aftermarket Forged piston like JE or ROSS, they come with a spreadsheet on how much to gap your rings based on the power it will be making.
Old Feb 23, 2012 | 05:27 AM
stockhatch's Avatar
stockhatch
Is this a factory fresh block, or a used one that has just been honed? If it's used, drop a few rings in and measure the gaps. I think you may be surprised.
Old Feb 23, 2012 | 10:27 AM
Shadowen's Avatar
Shadowen
Does the same sizing apply to me if I'm using a GE block with a GTE head?
I'm hoping to hit 500-600 rwhp range.
Old Feb 23, 2012 | 12:25 PM
phamxOC's Avatar
phamxOC
its a used block with with a fresh re-hone . machinist told me to use standard size rings. when i threw the rings :
1: 1st 0.020 2nd 0.022
2: 1st 0.020 2nd 0.020
3: 1st 0.020 2nd 0.022
4: 1st 0.019 2nd 0.022
5: 1st 0.020 2nd 0.022
6: 1st 0.022 2nd 0.022-23
these are NPR rings from driftmotion, i havent filed them or anything. does those numbers look right?
Old Feb 23, 2012 | 12:53 PM
phamxOC's Avatar
phamxOC
i think ge and gte are the same, only differences is the oil squirter. but u should check your bore size
Old Feb 23, 2012 | 01:49 PM
stockhatch's Avatar
stockhatch
Just as I thought. Since you have a seasoned block, you are outside of spec on them already. Even so, you are still within the service limits. Did you turn a piston upside-down and push the rings a couple inches down the bore and square them?
Spec for top ring is: (0.0118 - 0.0157) Service Limit: (0.0394)
Second ring: (0.0138 - 0.0178) Service Limit: (0.0413)
Oil ring: (0.0051 - 0.0150) Service Limit: (0.0386)
I wonder what your piston to wall clearance is?
Old Feb 23, 2012 | 03:18 PM
Shadowen's Avatar
Shadowen
They do have the same bore size, I just wasn't sure if the GTE pistons were different.
Old Feb 23, 2012 | 03:27 PM
phamxOC's Avatar
phamxOC
i believe its the stock bore.. what do u recommend the gap to be at? my other set of piston rings are 0.018 and 0.019 across the board...
Old Feb 23, 2012 | 03:30 PM
stockhatch's Avatar
stockhatch
I recommend the stock gaps I posted above, but you are already beyond them. By other set, do you mean your used stock rings? It is interesting that they have smaller gaps. Do they have carbon buildup on the ends, making the gaps just seem smaller?
Old Feb 23, 2012 | 03:45 PM
phamxOC's Avatar
phamxOC
am i suppose to push the rings half way down the cylinder and then measure it?
Old Feb 23, 2012 | 03:51 PM
phamxOC's Avatar
phamxOC
i pushed the rings half way down and it came out to .016
Old Feb 23, 2012 | 04:02 PM
stockhatch's Avatar
stockhatch
Which rings went to .016? Did your machine shop check for taper? Ideally, you have minimal taper in the bores. A .004-.006 change in gap within the stroke range of the bore seems like quite a bit to me. It is recommended to push the rings down halfway so the piston used to square them is fully into the bore, and "square" itself.
