the only other leaks i can think of that could cause alt. failure is a water pump leaking onto it or the valve cover gaskets. Either that or crappy alternators. Got any pics?
Just to help everyone else out, there's a seal at the bottom where the shaft goes through (by the helical gear). You'll see it when you look, mine had apparently shrunken enough to let oil by.
