Curious..how much does a battery run?
Old Oct 17, 2002 | 05:38 PM
mjr24's Avatar
mjr24
Default Curious..how much does a battery run?
From the dealer and from an auto parts store on average?
Old Oct 18, 2002 | 12:02 AM
strongsail's Avatar
strongsail
about $60 for a cheap one from walmart to $150 for an optima agm - the sc4 needs one with reverse terminals, remember
Old Oct 18, 2002 | 12:50 AM
mjr24's Avatar
mjr24
Strong....reverse terminals? Im not familiar with those?
Is there really any difference between a Walmart battery and a Lexus dealer battery qualitywise? I dont want to cut corners with the SC.
Old Oct 18, 2002 | 01:07 AM
strongsail's Avatar
strongsail
if you look at the top of a "standard" car battery, and the terminals are on the side away from you, the plus terminal is on the right and the minus terminal is on the left. Look at the battery in your sc400 and you will see that the plus terminal is on the left: the terminals are "reversed." Trying to get the leads to reach the terminals will be tough and the result will look sloppy unless you get a battery with "reverse terminals."
You need to compare specs to compare quality, the best walmart battery may be as good as the interstate or exide the dealer will sell you - the optima agm is a whole different design, higher quality, more powerful, more dough.
Old Oct 18, 2002 | 01:09 AM
mjr24's Avatar
mjr24
Ah ok....guess I never really noticed.
How about the quality of a Walmart opposed to any other?
Old Oct 18, 2002 | 01:11 AM
strongsail's Avatar
strongsail
interstate is a major vendor to many car dealers, here is a page from their website that talks about battery ratings - interstate sells optima too -
http://www.ibsa.com/www_2001/content...ts/ratings.asp
Old Oct 19, 2002 | 07:38 AM
Grimpy's Avatar
Grimpy
is $165 shipped for the D950 Yellow top Deep Cycle a good price?
Old Oct 19, 2002 | 04:37 PM
strongsail's Avatar
strongsail
you want to use it as a second battery to run audio? If so, it's fine, and the price including shipping seems pretty good. If you need a starting battery, it is absolutely the wrong one.
Old Oct 19, 2002 | 06:25 PM
928owner's Avatar
928owner
Talking
Actually, you can use a "regular" battery configuration for the SC400, as long as it is beefy enough. I bought one at Costco about 2-3 years ago.... and it is still going strong. You DO have to reverse the position of the battery, and stretch the battery cables a bit, but it works just fine.... and is a whole lot cheaper than the dealer. I just got to believe Lexus made the
"reverse" terminal configuration so you have to buy the battery from them.... but it just is not so.
Old Oct 20, 2002 | 12:12 AM
VQT's Avatar
VQT
I think you and I both like Lexus a lot since every good things about Lexus SC we have it with our cars. Door hinges, rear tires, P/S pump, A/C controller, CD changers...I got them all Damn rebadge Toyota
bigblack06
Hybrid Technology
Aug 24, 2025 11:59 AM
worker
Mar 22, 2025 02:26 AM
cdvmagic
Nov 3, 2008 01:19 PM
GS430 GUY
Mar 1, 2001 06:12 AM
