1JZ problems surprise surprise
Old Dec 14, 2011 | 09:08 PM
WetLexus's Avatar
WetLexus
Default 1JZ problems surprise surprise
So story goes, i test drove the car for the first time in a while. I get the car to spool for the first time because of boost leaks i had to figure out. I got it to spool once in first gear and after that the car doesnt wanna go over 2,000 rpms. Whether im in neutral or not the car doesnt want to rev over 2k rpms. First thing I did was check over the vacuum hoses in case one of them popped out but i get nothing!! I am not tuned and have no air/fuel controller whatsoever hooked up. Please help!!! I want to booost!!!!
Old Dec 14, 2011 | 09:51 PM
antonio356's Avatar
antonio356
MAP sensor?
Old Dec 14, 2011 | 10:07 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Didn't post in the engine forum, surprise surprise.
Moved for ya
Make sure you're car isn't in limp mode by resetting the ECU.
Old Dec 15, 2011 | 09:21 AM
WetLexus's Avatar
WetLexus
Lmao Touche O.L.T. , Touche. Thanks for moving the thread and Thanks for the replies. Ill try to reset the ecu. But even then I'm assuming I need to AT LEAST get an SAFC to tune this thing and that will fix my issue?
Old Dec 15, 2011 | 09:23 AM
WetLexus's Avatar
WetLexus
Originally Posted by antonio356
MAP sensor?
Map sensor is hooked both electronically and through vacuum
Old Dec 15, 2011 | 10:34 AM
stockhatch's Avatar
stockhatch
You keep saying tune, but what size injectors are you running?
Old Dec 15, 2011 | 01:40 PM
WetLexus's Avatar
WetLexus
I have 440cc injectors from a jdm 2jz.....nothing big
Old Dec 15, 2011 | 02:05 PM
BeansIS's Avatar
BeansIS
Try replacing it or trying out a known good unit..
Old Dec 15, 2011 | 02:14 PM
stockhatch's Avatar
stockhatch
Possible leaky cap, dying ecu as well. Crack it open and check it.
Old Dec 15, 2011 | 02:38 PM
99SC42's Avatar
99SC42
Jump E1 to T1 and check for CELs that 's the first thing i will do.
Old Dec 15, 2011 | 06:13 PM
PoGikoSc4's Avatar
PoGikoSc4
mine was the ECU...my old ECU didnt have signs of leaky caps but u might wana try diff ECU..GL
Old Dec 19, 2011 | 04:52 AM
WetLexus's Avatar
WetLexus
Thanks a lot for the replies everyone, Im going to go over all of the vacuum hoses and make sure I have no leaks. Im not really able to get my hands on an ECU yet, but its just weird that it was working fine before i boosted.......
estomax
Jun 13, 2015 08:12 AM
1jzchris
Jul 8, 2013 09:23 PM
trevor10
May 5, 2010 07:01 AM
Ali SC3
SC400 / 300 Classifieds
Dec 26, 2008 02:19 PM
Ric
Apr 25, 2006 05:41 PM
