1jz start up problems
Old Apr 6, 2010 | 09:53 AM
trevor10's Avatar
trevor10
Default 1jz start up problems
I swapped in a 1jzgte since my last one blew up. I checked all my sensors and they all have power but not sure if they have spark. It wants to turn over just doesnt have enough spark to start it. My teacher thinks it could be the ecu. We put a diode on one of my injectors and it only blinks once and it is suppose to blink more then that. We have been working on he problem for two weeks and i figured maybe someone on here may have had the same problem. Thanks
Old Apr 6, 2010 | 12:32 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
stock ecu?
Old Apr 6, 2010 | 12:50 PM
trevor10's Avatar
trevor10
1jz ecu, but the ecu was fine when my last motor was in
Old Apr 6, 2010 | 09:06 PM
trevor10's Avatar
trevor10
Anyone else have any idea? just through some ideas out anything helps
Old Apr 7, 2010 | 05:12 AM
Luv2xl's Avatar
Luv2xl
check the wiring from the engine harness connector to the crank sensor... Due to age, when tuggin and pulling they sometimes seperate. Not providing the right contact..
Old Apr 7, 2010 | 07:08 AM
trevor10's Avatar
trevor10
Just checked the crank sensor, still have power to the sensor thanks for the post though, keep them coming
Old Apr 7, 2010 | 09:39 AM
99SC42's Avatar
99SC42
ECU on the 1JZ will bad without any warning so it might be the ECU.
Old Apr 7, 2010 | 11:55 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
thats what i was thinking too, open it up to make sure.
could have something to do with why your last one went boom.
Old Apr 7, 2010 | 06:57 PM
trevor10's Avatar
trevor10
Yeah thats the only thing we have left to check and the ignitor, probably going to buy an ecu tonight or tomorrow. thanks everyone for the post, can keep them coming any advise helps
Old May 5, 2010 | 06:53 AM
trevor10's Avatar
trevor10
Well we found out my cams have no power going to them. They plug off the harness isnt putting power to the cams. Would an ignitor be the cause of this?
Old May 5, 2010 | 07:01 AM
BSC300TT's Avatar
BSC300TT
efi fuse?......
turbodremz
Aug 27, 2011 05:54 PM
okula247
SC400 / 300 Classifieds
Jul 24, 2010 03:21 PM
LSEGHATCH
Oct 17, 2007 08:05 PM
Deceptik1
Jul 20, 2006 06:35 AM
