Lighting question
Old Oct 12, 2002 | 01:48 AM
808SC300's Avatar
808SC300
Default Lighting question
When are the "cornering lights" supposed to come on? Do they come on only at driving speed or in gear? I was curious because while doing a test i have yet to see them come on. BTW the car is a 1992 SC 300. If it ends up just being the bulbs, is there a way to make these lights come on all the time with the headlights?
Old Oct 12, 2002 | 02:03 AM
lex400sc's Avatar
lex400sc
Cornering lights only activate when you hit your turn signals. You can wire a relay to keep them on whenever your city lights/headlights are on so that they in effect become fog lights. I wrote the battery relay instructions down a while back. Search for a thread like "Installing a Relay". I should put that in the FAQ actually...
Old Oct 12, 2002 | 02:13 AM
808SC300's Avatar
808SC300
Yeah, the thing is that even when i had the car in gear and parked with the lights and signals on the cornering lights still wouldn't come on. Maybe the bulbs are burnt out, are they known to go out with age?
Old Oct 12, 2002 | 02:34 AM
lex400sc's Avatar
lex400sc
Hmmm, possibly, but highly unlikely that both died at the same time. Check your fuse box before buying new bulbs. Here, I posted up the relay how-to in the FAQ thread for you: https://www.clublexus.com/forums/sho...631#post416631
Old Oct 12, 2002 | 03:20 AM
808SC300's Avatar
808SC300
OK... I looked in the engine compartment fuse box and couldn't find anything relating to corner lights. Am I overlooking something? Things would be way easier with a shop manual of some sort. Thanks again for your help
Old Oct 12, 2002 | 03:24 AM
lex400sc's Avatar
lex400sc
There's an auxiliary fuse box located above the driver foot well to the left side. My guess is that any fuse relating to the lights are in there.
Old Oct 12, 2002 | 09:09 AM
808SC300's Avatar
808SC300
I'm stuck, does anyone know what the fuse would be labeled for the corner lights? If it comes down to it i'm just gonna remove the bulbs and see if they're burnt out...i really want those things to work.
Old Oct 12, 2002 | 02:05 PM
Taka's Avatar
Taka
the fuse for the cornnering light system is #9 in Junction block No.1 (located by driver foot). they are 20A.
Old Oct 12, 2002 | 02:14 PM
RalAegidius's Avatar
RalAegidius
Aren't those lights pointing in the wrong directions to be useful as fog lights?
Ral
Old Oct 12, 2002 | 03:48 PM
lex400sc's Avatar
lex400sc
Ral, yeah, they are bit too wide and not as bright, but it sure does look better as a foglight then as cornering only. They will light up a lot more of the road side, where all the critters come from....
Old Oct 12, 2002 | 04:38 PM
pcmw's Avatar
pcmw
Ral,
I did mine a while back and put white bulbs in there. It is kinda funny being able to see the people next to you on the freeway at night. Even if they have limo tint, I can still see them.
MW
Old Oct 12, 2002 | 04:43 PM
Taka's Avatar
Taka
so it annoys other drivers? I think i'm gonna try that ...
Old Oct 12, 2002 | 05:38 PM
pcmw's Avatar
pcmw
Not bright enough to annoy anyone. If people were to look right at my bumper...maybe.
It is really kewl thou.
MW
Old Oct 12, 2002 | 06:57 PM
808SC300's Avatar
808SC300
OK, it ended up that one of the bulbs was burnt out. costed me $1.03 Now for using the cornering lights as fog lights...does this require me to remove that plethora of plastic guards underneath? It looks as if this is the only way to access the wires needed. Thanks again guys
Old Oct 12, 2002 | 07:00 PM
pcmw's Avatar
pcmw
Pull your head lights...
Way easier.
MW
dtLS400
Dec 29, 2011 11:59 PM
dinero718
Apr 19, 2007 05:17 PM
crilla
Lighting
Apr 14, 2006 07:41 PM
Woogie
Mar 20, 2005 05:23 PM
