Ruh-Roh........ engine noise
Old Nov 15, 2011 | 07:41 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Default Ruh-Roh........ engine noise
Sounds lower pitched (unlike a bearing normally would ) and very clearly a knocking.
Whatcha think?
http://www.youtube.com/watch?v=BvKAisZ-Ybo
Old Nov 15, 2011 | 07:59 AM
ihiryu's Avatar
ihiryu
Sounds like timing belt is shredded and hitting something. I honestly doubt that's the case, but that's what it sounds like to me.
Old Nov 15, 2011 | 08:01 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
The only thing I know for sure is it is a metal knock.I thought it was more towards the front. but when I get over the engine it seems more dead center inside it so I need to investigate further.
Old Nov 15, 2011 | 08:40 AM
sj408's Avatar
sj408
not sure what the sound is but out of curiousity is your accessory belt even moving???
im sure it is and my eyes are just being tricky but figured id ask
Old Nov 15, 2011 | 09:34 AM
stockhatch's Avatar
stockhatch
I would pop the belt off and run it just to be sure its not any of the accessories. The good news is that you have a spare 1UZ to swap in just in case, right?
Old Nov 15, 2011 | 09:58 AM
SexCoupe's Avatar
SexCoupe
does the sound speed up if you rev?remove the cam covers and run it
Old Nov 15, 2011 | 10:34 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Time to pull the extra motor out that you have listed in the classifieds and put in.. Lets hope not..
Old Nov 15, 2011 | 12:40 PM
HiPSI's Avatar
HiPSI
Sounds very repetitive like something is rubbing. I'd check under the timing cover and see if something is loose. If you climb under the car do you hear the noise or does it sound higher in the engine?
Old Nov 15, 2011 | 12:42 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Gonna do the smart thing.......... buy a new SC then fix this one. LOL.
Going to look at a DWP 95 SC4 in the am.
Old Nov 15, 2011 | 02:35 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
I mean tonight
Old Nov 15, 2011 | 03:15 PM
OG Dada's Avatar
OG Dada
Sounds like a cracked block?
Old Nov 15, 2011 | 04:08 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
The car "popped" and lost all power tonight so it seems more serious. I may throw my spare motor in there......and may not have a choice.
Old Nov 15, 2011 | 06:35 PM
TechGreek's Avatar
TechGreek
Damnit, I wish I would have seen this. That sounds exactly like the timing belt fluttering against the side of the cover.
A bearing is more pronounced, almost like an exhaust leak chug. This is my Galant after the dealership neglected to put about four quarters of oil in my car...then neglected it was their fault stating they use computers to fill a car *facepalm* I do work on computers for a living. I literally grenaded this motor when I got the other one in on the stand.
http://www.streetfire.net/video/valv...est_208137.htm
Old Nov 15, 2011 | 06:37 PM
BenStoked's Avatar
BenStoked
CL Folding 1,000,000
power as in electric or hp?
hearing it, my first thought was water pump (possible head gasket, now?)
Old Nov 16, 2011 | 05:42 AM
RyanV's Avatar
RyanV
Maybe it's the serpentine tensionser.
Doesnt sound like rod knock. Rod knock would start to clank as you revved it from metal on metal.
