bad battery cables?
Old Nov 12, 2011 | 05:35 PM
Avarec's Avatar
Avarec
Default bad battery cables?
i know ya'lll miss me, well i am back
i just got a '92 5spd sc300 few days back,
have a new alternator, and new battery, the car starts no problem with jumper cables on and as soon as i take cables off it shuts off, could it be bad connection at battery cables?
i did search and cant find much, i had alt checked and its good, and battery is brand new, interstate 800 amp cold start
Old Nov 12, 2011 | 05:44 PM
GS4_Fiend's Avatar
GS4_Fiend
get a DMM check from post + to - cable. and next is from post - to + cable. which ever has a difference in voltage, is the that needs to be replaced.
Old Nov 12, 2011 | 05:48 PM
Avarec's Avatar
Avarec
not really electrically inclined here
whats a ddm? like a voltage meter
also why enables alternator from charging the battery if the alt is good?
Old Nov 12, 2011 | 05:49 PM
Avarec's Avatar
Avarec
i meant what*
Old Nov 12, 2011 | 06:05 PM
xspsi6's Avatar
xspsi6
Sounds like the alternator even though it is new or the alt fuse is blown.
Old Nov 12, 2011 | 06:11 PM
Avarec's Avatar
Avarec
where exactly is the alternator fuse
when i put the battery in lights, etc work, , but if i move cables around or even touch them everything goes dead
Old Nov 12, 2011 | 09:39 PM
TechGreek's Avatar
TechGreek
Sounds like the connections from the alternator to the battery and car are bad.
Your car basically runs off the alternator whenever it's been running for a minute - the battery really is just the starting power.
If your connection from the alternator to the fuse box and/or battery is bad, it could cause your issues.
Alternator Fuse is in the main box, it's screwed into the left column at the top, you can't just pull it out but can visually see whether or not it's blown.
Old Nov 14, 2011 | 01:16 PM
Avarec's Avatar
Avarec
so ill need to go check the cables that run from alt to battery?
also when i hooked up the fresh new batt. they ding dong noise comes on, and if i move or even touch the cables around it goes away and car is dead, no open door noise or anything
Old Nov 14, 2011 | 03:04 PM
TechGreek's Avatar
TechGreek
That sounds like a bad ground, it could be broken internally inside the cable it self. I really would need to see some pictures, and if you would happen to have a volt meter around, that's your best bet.
Old Nov 14, 2011 | 08:42 PM
Avarec's Avatar
Avarec
where are the batt cables grounded to? do you know
thanks for taking youre time and walking me threw this, if youre ever in baltimore area, u have a nice 5spd coupe to ride around in
Old Nov 15, 2011 | 09:12 AM
TechGreek's Avatar
TechGreek
Your main grounds are going to be on the drive side of the block, there will be a junction point on the fender area off the terminal and cable (where the subframe bolts up to) and then the last point I'll have to look at.
I'll grab some pictures after my meeting here in a minute
Old Nov 28, 2011 | 10:14 PM
nandob's Avatar
nandob
I want to see those pictures, I am having the same exact issue. Car dies at any given time.I can wiggle my positive cable and I get power again. But when Im driving and I hit too many bumps the car flickers on and off and I have to stop and play with the positive cable again. SMMFH!
Old Nov 28, 2011 | 11:36 PM
GS4_Fiend's Avatar
GS4_Fiend
Tighten it up and if you can't replace with new one.
Old Nov 29, 2011 | 09:40 AM
nandob's Avatar
nandob
I've tightened it up so I guess I need to check my ground or get a new battery cable. SMH
BlaznLexus
Jul 25, 2020 10:28 AM
YoungNas
16
Dec 10, 2018 04:13 AM
ramo1246
May 27, 2011 05:26 PM
2ya
Aug 2, 2006 04:50 PM
SLVRGS
GS - 1st Gen (1993-1997)
Feb 3, 2004 11:54 AM
