Hub or Bearing Failure
Old Sep 24, 2011 | 05:14 PM
TechGreek's Avatar
TechGreek
Default Hub or Bearing Failure
So, trying to diagnose my noise issue (sounds like a rattle going down the road, with speed increasing) I took the entire front right side apart.
With everything broke down to just the hub, no rotor, caliper, etc. I could spin and hear a very faint noise at a certain position on every rotation but only if I speed it up turning wise, low turning speeds it didn't happen.
There is ZERO play at all in the front right with me yanking on at the proper positions but this noise is driving me insane.
Any ideas or suggestions towards this? I'm guessing the bearings are trashed or on the way out, but it's weird that there is no play and the noise is very quiet. I thought maybe the hub might have an issue but I'm not as experienced in this section of the car as others.
Old Sep 24, 2011 | 07:07 PM
Axmily's Avatar
Axmily
maybe control arm bushings??
Old Sep 24, 2011 | 07:09 PM
TechGreek's Avatar
TechGreek
Sorry, I forgot to add, spin the hub. I can spin the hub with no rotor on and hear the noise faintly only if I spin it at high speeds.
It's either the hub or the wheel bearing, I just don't see a wheel bearing having no play and making a noise like this.
The entire front end is brand new, UCA, LCA, End Links, Sway Bar bushings, tie rods, etc.
Old Sep 24, 2011 | 07:18 PM
mex lex's Avatar
mex lex
Did you check your brake pads? The wear indicator make a sound similar to what you are describing.
Old Sep 24, 2011 | 07:20 PM
TechGreek's Avatar
TechGreek
The noise happens with:
NO brake pads
NO calipers
NO rotors
On the hub...it's literally just the hub and studs and I'm spinning it like that.
This is not my wheel but this is what my view looked like during the testing.
Old Sep 24, 2011 | 07:37 PM
k7q's Avatar
k7q
maybe in bearing is just starting to go out. i had situation where the bearing was bad and make LOUD noise without any play in the hub
Old Sep 24, 2011 | 07:38 PM
TechGreek's Avatar
TechGreek
Yeah that's what I'm thinking. I am always down in the Suspension playing with something and have been chasing this noise for a month now or more.
Oh well, I'll pull a used one from the junk yard and rebuild that, and swap it out.
Old Sep 24, 2011 | 07:50 PM
account2x's Avatar
account2x
increases with speed = bearing
Old Sep 24, 2011 | 07:51 PM
TechGreek's Avatar
TechGreek
That's what I was going for, just seemed weird that it's only at one particular spot of the rotation and no play but if I caught it early (I'm a stickler for noises, I don't believe in the it's just that way theory).
Should I order a new hub too or just the bearing?
Old Sep 24, 2011 | 08:03 PM
OG Dada's Avatar
OG Dada
Yeah, it's definitely bearings, I've been riding on busted bearings for a month or 2 now and I'm finally gonna have time to fix it on Monday!
Old Sep 24, 2011 | 08:05 PM
TechGreek's Avatar
TechGreek
Well, I know the one at the junk yard was good as I played with it the other day while I was there so I'm just going to put it on and have the other one made like new, knuckle and all.
Old Sep 24, 2011 | 08:09 PM
OG Dada's Avatar
OG Dada
The bearings? I don't know about reusing old bearings, but buying a new one, I used Timken last time, and just pressing it in is gonna be the best way to do it. It's pretty easy after you get the hub off of your car.
Old Sep 24, 2011 | 08:20 PM
Tabaka's Avatar
Tabaka
sup friend Check it out, entire wheel hubs are only going for $60 dollars! I'm going to replace mine next weekend as well. I gotta run something else by you by PM.
http://cgi.ebay.com/ebaymotors/Wheel...item3a693ade6a
Old Sep 24, 2011 | 08:29 PM
account2x's Avatar
account2x
i would either find a used knuckle with hub and swap it over or rebuild your current one with a brand new bearing. the former option is a lot easier.
Old Sep 24, 2011 | 08:33 PM
TechGreek's Avatar
TechGreek
The bearing and hub are separate. The hub is where your studs press into.
I've got an entire knuckle with everything still sealed for $30 at the local pick a part that I'll swap in temporarily and then have my old one rebuilt and reconditioned.
I own a business in IT that requires me to be mobile so I can't pull it and bring it in and wait and go back. Needs to be a at Night operation so having a spare will come in handy.
