Cleaning the transmission pan
Subscribe
Sep 29, 2002 | 02:12 AM
Hi guys,
Has anyone cleaned the transmission pan and filter? Is it difficult to put back on? Also, did you use a pan gasket or a sealant (Three Bond 1281) to seal it back up?
Thanks,
DJL
Reply 0
Sep 29, 2002 | 06:23 PM
It’s mostly easy but reinstalling the pan is a little bit of a pain in the butt to maneuver the dip stick tube back into place. Cleaning is a cakewalk and just use a good high temp silicone sealant.
Reply 0
Sep 29, 2002 | 06:44 PM
Personally, I'd stick with the 1281. Just make sure that you torque each of the 19 bolts to spec. A tube of 1281 is about $14 and should last through several pan removals.
Reply 0
Subscribe
