So far, I've cleaned up the IACV, took the throttle body off and cleaned it up i case it was just sticking or something and nothing. I'm thinking that it is either the MAF or the EGR (noticed a crack in the EGR) and if not those two then probably the ECU. I'm going to work on determining whether it is one of those two before I spring for an ECU.
Any notes on getting an MAF? Did it change from year to year or engine to engine at all?
ECUs = about $2,500 at the dealer but can be had for as little as $100 or so used on eBay. If you buy used make sure you get the exact same model number as they changed even within model year.
Wait, what years are different? I bought an ECU from a 93 M/T vehicle to replace the one in my '95 and it works ok. Though I do have the idle issues as described from other people. I never had this issue before with my normal '95 ECU. I only changed because I had light white smoke at start up and almost everyone told me to change ECU's which I did. The funny thing is that I still have light white smoke at start up which goes away after the car warms up. I do not have a head gasket leak as I just had my car inspected with a leak down and compression test. I replaced my timing belt, water pump, every oil gasket, distributor, cap/rotor, plugs, etc and still have the same light smoke. The car runs fine for 15-20 minutes, then the RPM's drop rather low. I typically just restart the car at a stop light at idle and it runs normal for another 15-20 minutes. Sometimes I just turn on the A/C which makes the RPM's jump up 100-200 to keep things normal. I honestly don't care anymore as I just need this thing to be my daily for a little while until I can buy a new car. I've spent way too much on it already.
