blinkers stopped working completely
Old Jul 2, 2011 | 05:35 PM
MrHimbert's Avatar
MrHimbert
Default blinkers stopped working completely
so i clipped the cornering light plugs off, and spliced on some HID connectors cuz im going to be doing a projector retrofit into them, and now my blinkers dont work...i mean nothing at all, no sound, no lights, nothing....what happened? if its because i snipped the front, when i do the retro fit i will most likely wire it to an independent switch so how can i get them to still work if i do that? wire them into the side marker lights? thats what im guessing i would need to do, any help will be just peachy!!! thanks
Old Jul 2, 2011 | 05:37 PM
kapetajr's Avatar
kapetajr
Have you checked your fuses?
Old Jul 2, 2011 | 06:08 PM
MrHimbert's Avatar
MrHimbert
fuse is good to go, that's why its a little puzzling to me at the moment.
Old Jul 2, 2011 | 10:14 PM
OG Dada's Avatar
OG Dada
Might be the relay...
Old Jul 3, 2011 | 02:40 PM
MrHimbert's Avatar
MrHimbert
damn...where is that at? i gotta look up what kinda relay it is and what not...
Old Jul 3, 2011 | 02:52 PM
OG Dada's Avatar
OG Dada
It's near the foot pedal fuse box. Let me see if I can find a pic.
Old Jul 3, 2011 | 08:31 PM
MrHimbert's Avatar
MrHimbert
is it easy to visually see if its bad?
Old Jul 3, 2011 | 09:28 PM
OG Dada's Avatar
OG Dada
It depends, some are burned out, but some just shorted. Have you tried reconnecting the wires you disconnected? I'm not sure if the number of bulbs matter, because if you see the relay it says up to 4 bulbs can be plugged to it, so that might be the case, but normally if it senses that there's a bulb missing the blinking would go faster. But it's a pretty good idea to replace it since our cars are pretty old and you can buy the electronic ones so you can also use it if you're planning on changing the bulbs to LED.
Johnnyboi6
GX - 1st Gen (2003-2009)
Jul 8, 2014 06:22 AM
mk4r34
Feb 22, 2012 09:39 PM
tacomonkey
Jul 6, 2010 11:01 PM
steezy
CL of Hawaii
15
Aug 15, 2009 07:58 PM
