Question about LS400 brake upgrade
Old Jun 21, 2011 | 05:04 PM
Mero121's Avatar
Mero121
Question Question about LS400 brake upgrade
Hey CL! I just have a quick question on the front LS400 upgrade, I already have the rotors and calipers, but I am currently stuck, what other items are necessary to complete this job?
Old Jun 21, 2011 | 05:29 PM
MIGS's Avatar
MIGS
1. Pads
2. New brake fuid.
3. (optional, but i highly recommend) SS brake lines
4. (optionl also) 6-pack Coronas
Old Jun 21, 2011 | 05:47 PM
iceman400's Avatar
iceman400
You may also need 8 washers to push out the caliper bolts..also not necessary but you may want to do is ...caliper paint.
Old Jun 21, 2011 | 05:51 PM
iceman400's Avatar
iceman400
Originally Posted by MIGS
1. Pads
2. New brake fuid.
MIGS..
That 6pack sounds real good right now..
Old Jun 21, 2011 | 06:41 PM
Mero121's Avatar
Mero121
Thanks for all the responses! I definitely bought some caliper paint, I will post pics when i get it all done! but Ive encountered another problem, Am i going to need longer wheel studs with the washers? i put in the rotors and it seems to interfere with the tie rod end?, i know i have to cut the dust cover a bit, but im still stuck on this step haha
I am definitely getting that six pack tommorow, and for the ss brake lines, anyone know of a good site where i can purchase these?
Old Jun 21, 2011 | 06:58 PM
CalitriSC's Avatar
CalitriSC
Post pics when your done.
Old Jun 21, 2011 | 07:21 PM
MIGS's Avatar
MIGS
LS caliper bolts are shorter than SC bolts. Do ur self a favor and just pick up 4 LS bolts from the dealership. They are worth it. To hell with washers.
Fleabay sells brake lines for a good price.
Old Jun 21, 2011 | 08:16 PM
Mero121's Avatar
Mero121
I think i might have gotten a rotor that is too big, i bought it off a CL member, as i put to fit in the rotor the rotor interferes with the tie rod end, and im wondering if i have to buy the spacers to put it in before i mount the rotor? thanks for helpin me!
Old Jun 21, 2011 | 10:27 PM
MIGS's Avatar
MIGS
if u bought rotors for an '95-00 LS400, then they should slide-on with no problem, (assuming u already cut or flatten the dust sheild so the rotors fit and rotate properly) and shouldn't be hitting any tierods.
Old Jun 22, 2011 | 02:43 AM
ScBouncE's Avatar
ScBouncE
more details about the cutting or flattening the dust shield, whats the process?
Old Jun 22, 2011 | 06:20 AM
MIGS's Avatar
MIGS
http://www.supraforums.com/forum/sho.....The-Easy-way!
^step #4
Old Jun 22, 2011 | 06:41 AM
uras300's Avatar
uras300
I simply took off the dust shield on mine. Also, I used 2 washers per bolt to avoid the interference.
I had no trouble with driver side caliper but I did have to trim a bit to fit the passenger side caliper.
Old Jun 22, 2011 | 07:37 AM
iridebmx's Avatar
iridebmx
i just banged my dust shield back and out and cut the bottom. i also used the stock bolts and still got like 1/2inch of clearance...
Old Jun 22, 2011 | 08:36 AM
GS FONZy's Avatar
GS FONZy
I had this same issue with my 97. Shaving a little bit from the caliper solved the problem, but I still have the dead pedal though
TheDuecer
Jul 5, 2017 08:05 PM
cp2
Suspension and Brakes
May 19, 2015 02:48 PM
mnewxcv
Oct 9, 2013 09:33 AM
GS_Louis
Oct 12, 2012 06:47 PM
ElitistK
SC430 Classifieds
Aug 23, 2010 09:09 PM
