Brake Light Issue???
Old Jun 9, 2011 | 11:04 AM
FUZION's Avatar
FUZION
Default Brake Light Issue???
Ok so i had a brake light go out (1156 bulb) and i went to replace the bulb, still doesnt work. I put the new bulb in the other socket and it worked fine. So im guessing the 1156 socket/plug is bad. Are there any previous issues with the 95' tail lights, wires harness or bulbs? If its something in the wiring is bad then would it be a problem if i jumped the wires to power 2 bulbs from one set of wires?? these are the brake lights the 2 1156 bulbs...thanx
Old Jun 10, 2011 | 10:13 AM
FUZION's Avatar
FUZION
no one has this problem?
Old Jun 10, 2011 | 11:51 AM
MrHimbert's Avatar
MrHimbert
I would use a mutimeter and check for power at the plug first. If you don have power there poke into the wireing with ur multimeter just before the plug. If you still dont have power then start chasing wires
pilgrimpvd
Sep 15, 2017 06:18 AM
Stealth05
May 23, 2016 02:37 PM
DosyBoy
Mar 18, 2014 12:21 AM
AlDavison
Aug 4, 2011 06:53 PM
Ryeno
May 22, 2009 04:32 PM
