battery draining problem
Old May 9, 2011 | 07:50 PM
bryan767's Avatar
bryan767
Default battery draining problem
alrighty, so i swapped my motor from a sc300 that was running to a new shell after i got into a accident (i still drove on it so i know the accident didnt hurt anything).
anyway, for some reason after a full charge i put the battery in and turn it to the on position and my turbo timer is only reading ~10v. so something is drawing the amps. its not my wideband because i can hold the wideband sensor when the cars off so its not on or itd heat up. its not my mapecu because i cant connect to it or see any lights on. its not my radio because there are no lights on. so i have no idea.
i know what im going to have to do, i just need ideas on where to search with my multi meter. im goin to check my mapecu, wideband and radio just because i could be wrong. ill check the alternator and the positive battery cable going to the trunk (relocated battery). i just dont know what would draw all the amps even if it was a wire shorting somewhere.. the alternator just doesnt charge!
Old May 10, 2011 | 06:19 AM
99SC42's Avatar
99SC42
This is what i think happened.
your old SC was 92-94 with the 92-94 SCs the alternator plug is part of the engine harness.
on your new SC which looks like 95-96 the alternator plug is part on chassis harness its in the engine bay.
look in your engine bay you should find the oval alternator connector laying there , and if you look on your alternator it has the big round plug so the fix is you need to replace your alternator with the 95+ SC300 alternator the one with the oval plug and the plug goes on the top of it not on the back.
it happened to me 3 years ago after i did the same exact swap as you lol .
let me know.
Old May 10, 2011 | 06:46 AM
bryan767's Avatar
bryan767
yep. this is exactly what i realized this morning.
i have the 92 alt. plugged in, and its not feeding to anything. I read somewhere i could just rewire the oval plug to the round one since there both 3 wires.
thanks for the help sir!
Old May 10, 2011 | 07:13 AM
99SC42's Avatar
99SC42
Yes you could rewire the plug, but i had a 95 Alternator sitting so i just decide to swap it and be done.
It was frustrating ..
Old May 10, 2011 | 07:17 AM
bryan767's Avatar
bryan767
Oh u have no idea. Its been 7 months in the making and I want to light it on fire. But now I feel a bit relieved that my theory could be right. Thanks mate
Old May 10, 2011 | 05:01 PM
bryan767's Avatar
bryan767
HURRAY. it was the issue! thanks man
soooo lesson learned
IF you have a 92, 93 or 94 sc300 harness on your 1jzgte and your putting it in a 1995 sc300 you need to cut the oval plug on the chassie and put your round 92 plug on. the wire colors nearly exactly the same. white, black, yellow/green
mwwilliams
Feb 23, 2018 04:04 PM
rogerowens
Jul 12, 2016 04:14 AM
sam600rr
Jan 23, 2012 06:37 AM
UR2klose
Feb 13, 2010 06:45 PM
