turbocharging SC300 options
Old Sep 4, 2002 | 07:45 AM
FLex's Avatar
FLex
Default turbocharging SC300 options
What would be better: 1. turbocharging stock SC300 engine and upgrading tranny or 2. replace with Supra engine and tranny. Looking for low 12 sec 1/4 mile and 0-60 in low 4 sec. What would be the costs with labor?
Old Sep 4, 2002 | 11:48 AM
Legends6spd's Avatar
Legends6spd
let me beat someone to this...
many many post in regards to this topic.
the search function is the most powerful tool here
u'll have weeks of reading material here
not to blow you off, but you'll find everything you need in those post, and u can respond to those if you like.
Old Sep 4, 2002 | 09:52 PM
pcmw's Avatar
pcmw
FLex,
I would think that if your engine is in decent shape and you are like most people, value conscious. Then option #1 is the way to go. For $6500 or so...you are done. Supra TT swap is probably double that or more.
MW
Old Sep 4, 2002 | 10:43 PM
ChrisSC300's Avatar
ChrisSC300
You would get more HP out of turbo'n your stock engine than you would if you swapped in a supra TT engine. Plus, it is around 7.5k for a complete turbo setup for the 2jz-ge and you would probibly spend around 12k for a 2jz-gte and tranny. Not to mention you need the Supra ECU and other things. You can make around 450rwhp on pump gas and in the 500's on race gas on the sc300 engine. The supra engine will probibly turn out around 420rwhp with some tuning and uping the boost. This is on stock turbo's though....if you are looking for huge hp #' then you can always dump ANOTHER 10k and upgrade the turbo's.
Old Sep 4, 2002 | 11:08 PM
Dew23's Avatar
Dew23
Where are you getting your prices from you can get a motor complete for about $3500.00with the auto drive shaft and rear end $700.00 wiring $1000.00 if you are not handy with tools .
This looks like$5200.00 to me now if you get greedyyou can spend lots more, i personally am going the swap route as my car will converted to stick.
Old Sep 4, 2002 | 11:35 PM
pcmw's Avatar
pcmw
I think PHR charges $10k+ to do the swap.
I think the difficult is in finding the parts first. Turbo parts are alot easier to source.
MW
Old Sep 5, 2002 | 12:24 AM
SC300T's Avatar
SC300T
Bean, is that you?
Old Sep 5, 2002 | 12:56 AM
Bean's Avatar
Bean
CL Folding 1,000,000
Nope
I dunno if I've ever seen a engine/tranny 2jz for $3500
more like $4500 or $5k... and the rear end usually runs around $700...
I'm a 'turbocharge the ge motor' fanatic remember?
Old Sep 5, 2002 | 03:33 AM
Deceptik1's Avatar
Deceptik1
I've seen a j spec 2jzgte for $2200 no harness and ecu, but I know of a place that makes harness' for $500 and have seen ECU's going for $350. The tranny $2000 and don't know about the other tidbits.
Old Sep 5, 2002 | 05:56 PM
Dew23's Avatar
Dew23
I got my engine for a good deal $1200.00 from my friend who imports engines inc trannywhich i sold back to him when i decided
to go 6sp which he has had a shift kit installed in it for hit turbo gs300. It helps when your friend imports stuff, i am waiting on my exhaust which should clear customs tommrow will take a pic it's
3"pipeing all the way through .
Old Sep 5, 2002 | 08:37 PM
FLex's Avatar
FLex
Originally posted by Dewsc300
I got my engine for a good deal $1200.00 from my friend who imports engines inc tranny ...
Anyway to get a "friends and family" ClubLexus deal with your importer friend for a Supra engine and tranny? I just had to ask.
Old Sep 6, 2002 | 11:26 AM
Slick Lex Coupe's Avatar
Slick Lex Coupe
what kind of exhaust you getting?
Old Sep 6, 2002 | 01:12 PM
Bean's Avatar
Bean
the jspec motor is pretty much inferior to the US-spec... smaller injectors... different sized turbos... and a less-wild cam profile (i think)...
not a good basis to start off of; might as well spend the same or similar money for a bigger badder US version
Old Sep 6, 2002 | 10:51 PM
Dew23's Avatar
Dew23
The j spec motor is not inferior has smaller inj and turbos but in my case it is not a problem as i am going t78 or t88 have both i will try the 78 first and see how i like it .So now i am selling my vpc
and e'manage with the inj and fuel harnes and the soft ware.The
the j spec is map already. my exhaust which i have been waiting onfor 3mths is still in customs should have it by tuesday.
I am hopeing to make decent power when it is finish 850cc inj and bliz 272int 272exh cams and some other litle tricks.
Old Sep 7, 2002 | 12:52 PM
SC300TURBO's Avatar
SC300TURBO
buy a toyomoto turbo kit for your car and be happy...on a stage 2 i went 11.90@115 on pump gas and good tires...you dont need the swap...and the swap needs alot of little parts that really add up fast....little crap like moving the power steering resivior...and alot of other little things....just turbo your motor and have a 400+ rwhp car that you can drive everyday...toyomoto can get you where you want for the right cash...if you have questions feel free to email me
Jeff
Rage5.00
Sep 4, 2009 07:39 AM
jtjohnny03
Aug 23, 2004 09:59 AM
VSsc400
Oct 10, 2002 09:25 PM
msray
Jul 27, 2001 05:11 PM
prvman
IS - 1st Gen (2001-2005)
May 9, 2001 04:09 PM
