Which Wire Did They Cut? Please Help!
I bought a section of the engine harness that has the wiring for:
the oil pressure light switch
oil level control switch
aircon pump wiring
The harness section plugs into the main harness using a large black plug at the rear of the
inlet manifold.
It's theoretically the harness for the A/C compressor.
Now for the issue:
I see a total of five plugs, not including the black plug that connects to the main engine harness. There is also a plug that has (blue, brown, green (with yellow stripe) wires going into it. This plug has been cut. I bet any money it's the A/C compressor plug, I just want to make sure.
I know it's a long shot, but if any of you guys can check the colour of the wires going into the AC compressor, it would be greatly appreciated. Another option would be a document listing the plugs for the said harness.
Thank in Advance,
Nick from Toronto.
https://www.clublexus.com/gallery/da.../ACdiy_004.jpg
from the DIY: https://www.clublexus.com/forums/per...tallation.html
