Lend a helping hand please.
Old Mar 7, 2011 | 09:57 PM
gijohnnyb's Avatar
gijohnnyb
Default Lend a helping hand please.
I am currently trying to get a feel for the cost of my project, 2JZGTE swap into an SC300. Below I have accumulated a rough estimate of what this is going to cost me. For those of you who have done the swap in the past, please take a look and help me complete/correct the list so that I have an accurate idea of how much money I am going to need to dish out for this. Any other advice or constructive criticism is also welcome.
PLEASE do not turn this thread into a debate over which engine or tranny is a better combo or swap. I have already made up my mind on the WHAT..not I just need your help with the how. Thanks.
Originally Posted by SC300 swap list
The basics:
199X SC300 @ $3500 (after I actually have cash in hand I will post up a WTB for a rolling shell near Orlando)
2JZGTE + R154 tranny @ $2900 shipped
Driveshaft - (i hear I may need to use half from a supra and the other half from the sc300) - @$400
Exhaust w/downpipe - @$700
Clutch - @$250
Sub Total: = @ 7750.00
Parts:
Timing belt (will USDM fit a JDM motor?) - $20
Spark Plugs (6) - $10
Oil / Coolant - @$80
Gasket / Seal kit (rear main seal)- $16 Is it worth doing the head gasket while the motor is out or should I just leave it alone?
Front mount intercooler (600HP)- @$360.00
Rubber hoses - $?
Engine Mounts (PN#: ) - $152.00
Water Pump – $50
Clutch Master Cylinder (PN#: ) - $
MKIV TT Fuel Pump - $240
Thermostat - $20
Foot pedal assembly - @$30
Sub Total: = @$951.00
TOTAL: = @$8701.00
Old Mar 7, 2011 | 10:07 PM
SChema's Avatar
SChema
I know this is not all that's left but wiring is going to be a critical step as well. I'm assuming factory ECU with piggy back fuel controller?
Old Mar 7, 2011 | 11:46 PM
gijohnnyb's Avatar
gijohnnyb
Wiring shouldnt be an issue, I have the help of a reputable shop. But why am I going to need a piggy back? I understand the need for it later when I upgrader and need tuning, but to get it running on stock twins for now, is it necessary?
Old Mar 8, 2011 | 02:31 AM
lexforlife's Avatar
lexforlife
add another 400 ish for good clutch add another 300ish for downpipe / midpipe and exhaust and overall add another 1500 as a cushion for unforseens.. trust me been there done that
unless you got a bad motor , leave motor unopened , toyota does it the best and i dont believe in messing with front and rear mains unless theres evidence of seapage.. again toyota does it the best.. i have over 35k boosted miles on my motor since buying my coupe in 2007 and making 600 rwhp and have never touch front or rear mains and they are perfectly fine .. ususally fronts only go when crankcase is not being evacuated of pressure correctly
Old Mar 8, 2011 | 03:31 AM
gijohnnyb's Avatar
gijohnnyb
So you're saying a good clutch is going to run me $750 and exhaust is going to be $1000? Okay, I will go with that...anything else? Anyone have input on this ECU thing?
Old Mar 8, 2011 | 06:41 AM
SChema's Avatar
SChema
If you leave it factory, no piggy back. Just use Supra/Aristo ECU.
Old Mar 8, 2011 | 06:53 AM
TURBO819's Avatar
TURBO819
Default 2jzgte Swap Parts & Prices
2jzgte Swap Parts & Prices.
Originally Posted by TURBO819
Parts & Price List
01: Aristo 2jzgte vvti Engine With Uncut Harness $1885.00
02: Aristo 2jzgte vvti ECU $333.00
03: Phoenix Tuning Hybrid Engine Harness SC300 / Aristo (Club Lexus Member Dr.Tweak) $750.00
04: Supra Twin Turbo Throttle Cable (SupraForum Member) $26.00
05: Supra Twin Turbo Side Mounted Intercooler Hose & Pipes (SupraForum Member) $65.00
06: Snap Performance 3" Down Pipe (Club Lexus Member Supra600) $280.00
07: 98-00 SC300 Upper/Lower Oil Pan & Engine Wire Harness (Club Lexus MemberR J Dist) $275.00
08: SC300 Timing Belt (13568-49036) $26.27
09: Fuel Return Line (Summit) SUM-PUMPKIT1 $85.95
10: Supra Twin Turbo Thermostat (90916-03093) $19.70
11: Supra Twin Turbo Thermostat Gasket (16325-62010) $5.72
12: Supra Twin Turbo Water Pump (16100-49846) $177.78
13: Supra Twin Turbo Gasket (90430-12005) x 2 $1.10
14: Supra Twin Turbo Union (90405-09174) $7.14
15: Supra Twin Turbo Pipe Turbo Oil (15474-88401) $44.11
16: Supra Twin Turbo Gasket Turbo Oil (15471-46010) $2.83
17: Supra Twin Turbo Hose Turbo Oil (15491-46020) $15.38
18: Supra Twin Turbo Hose Turbo Oil (15492-46020) $15.38
19: Supra Twin Turbo Pipe Turbo Oil (15482-46011) $96.45
20: Supra Twin Turbo Gasket Turbo Oil (15472-46010) $4.62
21: Supra Twin Turbo Bolt, Stud (90116-08348) x 2 $1.07
22: Supra Twin Turbo Nut (90179-08153) x 2 .98
23: Supra Twin Turbo Upper Radiator Hose & Strut/Springs (Club Lexus Member RikTT) $100.00
24: AEM Wideband UEGO Gauge Kit (30-4100) $205.00
25: DEFI 52mm WHITE RACER BOOST GAUGE (DF06503) $173.95
26: Supra Twin Turbo Side Mounted Intercooler (Had This item Since 1999. I Think I Paid) $125.00
27: T-Bolt Clamp (S&K Speed) x 2 $6.99
28: T-Bolt Clamp (S&K Speed) $8.99
29: Antifreeze Toyota Supra Twin Turbo (00272-1LLAC-01) $30.16
30: Supra Twin Turbo Fan Blade (16361-46060) $144.51
31: 98-00 GS 300 Aristo Ram Air Intake $34.00
32: Walbro 255 Fuel Pump (Club Lexus Member $hogunn) FREE
33: LS400 Front Calipers (Club Lexus Member aliga) $200.00
34: Supra Twin Turbo Rims (Club Lexus Member Erollinc) $535.00 Shipped
35: W58 Transmission (Club Lexus Member aliga) $1000.00
36: FlyWheel Bolts (90910-02103)
37: Hose,Ventilation (12263-46010)
38: Hose,Ventilation (12264-46010)
39: INSULATOR ASSY (12360-46111) Supra Twin Turbo MKIV Motor Mount X 2 $69.72
40: Sensor, Water (89422-16010) (2000 Toyota Corolla Three Wire Water Temperature Sensor) $53.79
41: Engine PCV Valve (12204-46020) Cost 4.10
42: Engine PCV Grommet 90480-18001 Cost 4.83
43: Intake cam cover gasket VVTI 1213-46030 Cost 11.20
44: Intake cam cover gasket VVTI 1214-46030 Cost 11.20
45: Rod Bolts (13265-46020 ) List 3.43 Cost 2.58 X 12
46: Rings Set (13011-46051) List 237.55 Cost 175.00 [ std only]
47: Snap Ring (90521-25004) List 2.34 Cost 1.79 X 12
48: Main Bearing (11071-46020-03) List 29.79 Cost 22.75
49: Main Bearing (11701-46020-03) List 27.93 Cost 21.32 X 2
50: Main Bearing (11701-46020-02) List 27.93 Cost 21.32 X 4
51: Thurst Washer Set (11011-46030) List 40.98 Cost 31.00
52: Main Cap Bolt (90910-02104) List 4.17 Cost 3.00 X 14
53: Mkiv Twin Turbo Full Engine Gasket Kit (04111-46094 ) List 480.77 Cost 365.00
54: Mkiv Twin Turbo Oil Pump Assembly (15100-46052) List 226.76 Cost 173.14
Old Mar 8, 2011 | 07:56 PM
gijohnnyb's Avatar
gijohnnyb
^^^ Awesome! Thats what I was looking for!
Quickly weeding through that and adding some things that I may not necessarily need, I have only added $450 worth of more parts. Which still puts me within my intended budget...and IF I can find a rolling shell or a cheap 300, then I will be well within range.
rowdisc300
Oct 28, 2012 07:54 PM
AZBMW
Dec 28, 2011 09:46 PM
zrs6v4
Apr 30, 2008 07:17 PM
vvtisoarer
SC400 / 300 Classifieds
Mar 21, 2006 05:04 PM
SCandilous
Jul 15, 2005 08:08 AM
