Gauge cluster question
Could having a blown dash light cause the fuse to blow?
I have had this problem with the car since day one when I bought it last week. The 15a fuse for the gauge cluster and thermo controls constantly blows. I have taken the cluster out and re-wired in a factory radio. I found a shady wire connected to the dimmer control that I took out and soldered back to factory.
I'm at a loss here guys....all the wires look good every where else. If someone knows anything...other than find the ground...it would help out a lot!
Is there a neutral start switch somewhere I could check. I just read of the same problem happening to someone camery. They concluded the neutral switch was bad
http://www.taninautoelectronix.com/G...sis-s/1909.htm
Let us know if you have any questions at all. We are happy to assist you any time.
Thank you,
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
262-456-4147
mr29rose
SC- 1st Gen (1992-2000)
06-19-10 05:57 PM
