Issue With Sea Foam
Old Nov 30, 2010 | 11:20 AM
TroySC300's Avatar
TroySC300
Originally Posted by Avarec
sea foam is junk, will mess up ur engine in long run, after it clears up all the gunk where does it go smart folks????
You must have forgotten about the ENORMOUS white clouds that pour out the back of the exhaust. Seafoam rocks. I used it on my 180k miles SC300 and it made a huge difference. Drove the hell out of that car until 205k miles and never had a single issue. Did the same thing to my 52k mile SC300 and it now has 75k miles and NO PROBLEMS!
Old Nov 30, 2010 | 02:26 PM
mktbully's Avatar
mktbully
like the other poster said...it'll get burned out of the exhaust. otherwise it goes into your oil and i assume you change your oil every so often...right?
Old Nov 30, 2010 | 02:31 PM
rpk2012's Avatar
rpk2012
Kinda like u stated, you always want to do an oil change after using sea foam.
Old Nov 30, 2010 | 02:35 PM
mktbully's Avatar
mktbully
yup...or very soon after.
Old Nov 30, 2010 | 03:49 PM
socal72's Avatar
socal72
Originally Posted by SC_coupe
Sounds about normal but 1500 at start is a bit high.
Cracked vacuum hose caused my Soarer to do all sorts of weird things at idle, might want to check that.
Idle Air Control Valve is know on these cars to malfunction after oil and gunk buildup causing erratic idling, there's tons of information regarding dis-assembly and cleaning procedures.
Just to add, I seafoamed my SC400 about 6,000km ago in the summer and it has idles noticeably better since, seems to run slightly smoother but that could just be me.
A rebuild huh, never knew you could rebuild them. i did remove the hose and happen to see some power steering fluid in the one that goes to the intake, what causes that?
Old Nov 30, 2010 | 04:02 PM
socal72's Avatar
socal72
Originally Posted by good2go
If you've got one cracked vacuum hose, you've probably got others too. Give them all a good looking over; that can definitely be affecting your idle.
Jut noticed that the hose that comes from the brake booster to the intake has cracks too. Looks like your right its sucking in extra air from all over the place. Guess i'll just change them all out. Can i replace them with a better grade like silicone? Or should I just go OEM?
Old Nov 30, 2010 | 04:13 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Depends on your budget. I say whichever is cheaper. JMO. Seafoam is the bomb!
Old Nov 30, 2010 | 04:56 PM
socal72's Avatar
socal72
I'm ok either way, just want the best fix don't want to do this again any time soon. Sea Foam FTW
Old Nov 30, 2010 | 07:00 PM
good2go's Avatar
good2go
There is a thread here about this. Apparently it's the vacuum switch on the power steering rack that's failing and allows fluid into the vacuum line. If I'm not mistaken, the thread was made by "O. L. T. ". Try searching for it; it's definitely something you'll want to fix.
Here, I found it:
https://www.clublexus.com/forums/per...s-one-out.html
Old Nov 30, 2010 | 08:08 PM
socal72's Avatar
socal72
Here, I found it:
Oh no, I knew something was wrong. I went outside and checked the vac line that comes from the intake to the side of power steering pump and your right, I can see and even drip a little fluid out onto my finger, Is this the reason why i would sometimes see white smoke at start up? Just so you know i do not have the white smoke at start up since I've Sea Foamed and oil changed the car, just the higher idle now . How soon should i fix this? Should i even be driving the car? I'm a little freaked out by this now!
Old Dec 1, 2010 | 08:19 AM
socal72's Avatar
socal72
Here, I found it:
I read the thread and understand what I need to do now. Thank you for taking the time to help me out with this issue. I'll be fixing this right away, along with replacing all vac lines and hoses with silicone. THANKS TO EVERY ONE WHO HELPED ME OUT WITH THIS!!! CLUB LEXUS FTW! (sorry didn't mean to shout)...HA HA
Oh almost forgot to thank the man behind it all "O.L.T" A MILLION THANKS TO YOU MAN YOU ROCK OK im done now...
Old Dec 1, 2010 | 09:34 AM
Avarec's Avatar
Avarec
an experienced engine builder once told me that its harmful for engine, all the internal build up is conceited in one spot that shouldn't affect the engines ability to function, when the crap gets burned it goes down through youre piston rings,
i am NOT making this ***** up, i am no mech but some one with high experience in this field should vouch this theory
if its too good to be true its probably is
but once again id love to be proven wrong and if facts are presented ill go use one in my own car
Old Dec 1, 2010 | 10:27 AM
mktbully's Avatar
mktbully
ok so let me add a little color...
does seafoam help? sure.
does it really clean that much? nope (not the amount that you think).
whats that white smoke? thats the seafoam burning out.
seafoam looks to be (more or less) refined kerosene. it's a light light oil. it'll burn when ignited. it will not chip away years of old carbon...at least not enough to clog anything. it will clean away a little of the deposit that's in the intake and combustion chamber but not the amount you think it does. remember you're not pulling in a large amount of it. the instructions is telling you to pull in the seafoam slowly not just pour it in. it'll clean up the oily residue but not the caked on carbon. just my .02.
LS400Eddo
65
May 8, 2021 08:50 PM
Moarpower
Aug 21, 2017 02:58 PM
MValentine
20
Mar 19, 2012 07:29 PM
outlaws
Dec 25, 2009 12:51 AM
SCotty P
Sep 18, 2008 02:51 PM
