Whinning sound from engine
Old Nov 26, 2010 | 05:11 PM
aamir007's Avatar
aamir007
Default Whinning sound from engine
Recently, i am hearing a whinning sound from the engine bay. It is coming from the belt/ac compressor area. The mechanic says that its not the ac compressor. He changed a bearing behind the idler pulley but the sound did not go away. Any suggestions on the source of this noise will be appreciated. By the way I have a 1993 SC400 with 150k miles in immaculate condition.
Old Nov 27, 2010 | 10:20 AM
ShortyPH's Avatar
ShortyPH
Maybe ac clutch or a pulley or some random stuff stuck into a pulley. Check if all the hoses clear the pulleys etc.
Old Nov 27, 2010 | 10:50 AM
good2go's Avatar
good2go
It could also be your PS or ALT. Try listening through a stick or something to see if you can identify the source better. You can also remove the belt and manually spin all the pulleys to see if you can reproduce the sound. This doesn't always work though because you can't spin them as fast as the engine does, but maybe you'll get lucky.
Old Nov 27, 2010 | 11:09 AM
One HoT's Avatar
One HoT
CL Folding 10,000
on the 400 the power steering is notorious for whining sounds.
ToyotaJon
RC F (2015-present)
Dec 10, 2017 07:45 PM
stuhrw
GX - 1st Gen (2003-2009)
Feb 4, 2016 05:57 AM
jbone29
Jun 12, 2012 10:23 PM
sc400123
Sep 18, 2009 10:33 AM
Vortes
Sep 8, 2008 02:52 PM
