hey guys!!
Old Nov 21, 2010 | 09:30 PM
SCupra300's Avatar
SCupra300
Question hey guys!!
did anyone changed their small side window on sc3 , somebody broke onto my car. i bought the window wanted to ask if it's hard to install myself?
thanks
Old Nov 21, 2010 | 09:35 PM
Black_SC's Avatar
Black_SC
i probably wouldnt attempt to do it myself...but thats just me...
Old Nov 21, 2010 | 09:46 PM
SCupra300's Avatar
SCupra300
but do you know if there is any brackets from inside or it's just the silicone?and how to replace the molding from outside around the glass, Thanks again
Old Nov 22, 2010 | 12:38 AM
Han7's Avatar
Han7
There are 3 studs from the window that you will need to remove the nuts on
Rear seats, lower rear panel, Oh !#$% Handle, and then pull the upper trim out.
After that you will see the 3 mentioned nuts.
A putty knife may help as it also attached with sealant to keep water out
Old Nov 22, 2010 | 10:43 AM
SCupra300's Avatar
SCupra300
thanks a lot!!! i'let you know how it went!
Old Nov 22, 2010 | 11:02 AM
Sc4Jr24's Avatar
Sc4Jr24
It sucks that you have to remove the rear seat just to get the panel off. I broke my panel thinking it was a clip holding it in. Your gonna have to remove that sealant to get that window off and I think a heat gun would help or cut it out.
Old Nov 22, 2010 | 10:35 PM
SCupra300's Avatar
SCupra300
oh really i have to remove the rear seat too? thats what i thought: it all on clips. but you say its not? can you please explain how to do it?the steps to gett to it. thanks i really appreciated your time !!!
Old Nov 23, 2010 | 07:15 AM
RedPhoenix's Avatar
RedPhoenix
I replaced a buddy of mines... remove the interior around it and you can see what needs to be done. I used window weld to reseal it after.
Old Nov 23, 2010 | 09:41 AM
Sc4Jr24's Avatar
Sc4Jr24
There are a few clips tucked behind the seats that I couldnt get too. I pulled the panel hard and broke a couple of those clips. now I cant get the panel to seat right. Here is what you have to remove and you will see: seat belt, the handle up to, pop up panel in the door seal just to uncover the back panel and slowly pull rear panel back. You should now see rear window trim and what has to be removed.
This should give you an idea. Its not everything but once you start pulling back you will see. Be careful on pulling on panels. Mine was broke from previous owner.
Old Nov 24, 2010 | 06:41 PM
SCupra300's Avatar
SCupra300
Default thanks
Thank u very much I appreciated!!!
Old Nov 24, 2010 | 06:59 PM
broda805's Avatar
broda805
If you look up rear speaker removal it shows you how in a write up just stop following it once the panel is off
Old Nov 25, 2010 | 03:36 PM
SCupra300's Avatar
SCupra300
thanks!But where can i look it up? do u know any websites? i tried to google it nothing useful came up, i don''t want to break the clips!!! thanks again
speed6
May 20, 2014 11:42 AM
xspsi6
Jun 22, 2012 10:28 PM
xspsi6
Sep 11, 2011 10:05 AM
no1gsxr
Maintenance
Dec 9, 2008 06:48 AM
hellasboy
Oct 22, 2002 02:49 PM
