Strange question...
Old Nov 2, 2010 | 01:03 AM
bkempf7's Avatar
bkempf7
Exclamation Strange question...
Okay, I’ve taken my entire center console apart to repaint it (just the ash tray, and plastic around shifter). I want to do a clean job, so does anybody know how to remove the “PRND2L” plastic part that is for the shifter. I see the clips attaching it to the console piece but do not know how to safely remove them without breaking them off.
Thanks!
These are the PRN... “buttons” and I need them removed from the rest of the console piece.
Uploaded with ImageShack.us
Here a picture of the PRND2L strip from behind, I need this strip removed properly (as you can see I’ve already chipped a piece off)
Old Nov 2, 2010 | 01:07 AM
SH_JZZ30's Avatar
SH_JZZ30
Did you remove the shift ****? Pull the bottom part of the **** down and you should see 2 Phillips screws. Then you can pop off the shifter plate and remove the plugs underneath.
Old Nov 2, 2010 | 01:16 AM
bkempf7's Avatar
bkempf7
Sorry, I may need to edit my post. I’ve already removed that part, I just need to know how to get the actual PNRD2L “buttons” off. I’ll throw in some pics to clarify.
Old Nov 2, 2010 | 04:54 AM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
are those screws? if not then probably rivets, then nope unless u break them and rerivet it.
Old Nov 2, 2010 | 05:57 AM
MMCtuner's Avatar
MMCtuner
With a heated knife or similar you can put that apart but after that you will need to put some plastic again or glue it. With a drill you can take it apart too, but there´s more room to mess up something.
Old Nov 2, 2010 | 09:01 AM
turbodremz's Avatar
turbodremz
^^^^^**EDIT**, ^^ this is actually correct, your trim piece is different than mine
Old Nov 2, 2010 | 12:08 PM
bkempf7's Avatar
bkempf7
thanks for all the advise.
jimmymac30
Jun 27, 2021 11:10 AM
bbrowncods
GX - 1st Gen (2003-2009)
Apr 29, 2016 07:02 AM
booga
Jul 4, 2011 01:23 PM
snook
Nov 15, 2009 06:48 PM
tskolak
Jul 10, 2007 02:02 PM
