Timing Belt
Old Oct 18, 2010 | 12:58 PM
1uzfe4147's Avatar
1uzfe4147
Default Timing Belt
Did i set my timing right?
http://sphotos.ak.fbcdn.net/hphotos-..._3472670_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-...9_639437_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-...1_300169_n.jpg
Old Oct 18, 2010 | 01:01 PM
1uzfe4147's Avatar
1uzfe4147
Only reason i ask is because she does not start. Replaced the water pump and timing belt, and she ran perfectly fine beforehand. ( 92 sc400 )
Old Oct 18, 2010 | 01:37 PM
1uzfe4147's Avatar
1uzfe4147
When i turn the crank, sometimes i get random resistance and it feels like it trys too go back the other direction a little.
Nvm this is from compression.
Old Oct 18, 2010 | 02:50 PM
93MSB's Avatar
93MSB
heres a pic from the service manual
did you pull the distributor when you changed the belt?
Old Oct 18, 2010 | 03:00 PM
1uzfe4147's Avatar
1uzfe4147
Thank you for the reply!!
the distributor cap and rotor? yes. well dangit all. i have the timing right then. this just makes everything confusing...
Old Oct 18, 2010 | 03:40 PM
1uzfe4147's Avatar
1uzfe4147
Might be ground wires, tomorrow ill have too check. i think i broke the bolt on one of my ground wires, but i replaced it with another bolt. maybe its not getting a good connection? Could that be possible?
Old Oct 20, 2010 | 11:28 AM
93MSB's Avatar
93MSB
does the starter turn? or is it not turning the engine over at all?
Old Oct 20, 2010 | 03:56 PM
1uzfe4147's Avatar
1uzfe4147
Here i am going too update this thread.
92 SC400 1uz-FE
I replaced the Water pump and timing belt, before i changed them the belt was fine and the Water pump was just leaking a little. So the engine fired up and i was able too drive. So i went ahead and took her apart and replaced. Now everything is back together except i haven't put coolant fluid or engine fan fluid in yet. I try too start her up and i can hear a couple exhaust notes coming from the back but she wont start? I checked the grounds, cleaned spark plugs, can even smell gas. Checked all my fuse's and made sure i plugged all vacuum lines, and wire cables in. Anyone have any idea what could be wrong?
spitfire7
Jan 27, 2015 09:19 AM
Farino81
Jun 9, 2009 08:54 PM
swat1727
Dec 11, 2008 12:44 PM
SLEXC400
Maintenance
Jan 12, 2008 11:58 AM
