Replacing Cluster Lights
Old Oct 5, 2010 | 10:10 PM
ALLWiTE2JZ's Avatar
ALLWiTE2JZ
Default Replacing Cluster Lights
Old Oct 6, 2010 | 07:36 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Spend the 100 buck at Lextech. They offer lifetime guarantee and do a very fast turn around. Well worth the money IMO.
Yes they are size 24 for the backlighting, and they are 8 of them.
Old Oct 6, 2010 | 08:04 AM
MMCtuner's Avatar
MMCtuner
Try to put the dimmer at the lowest and in a few hours look if they are working.
If they work that way you must clean them and then you´ll have your needles back to life. It´s free. Hope it helps.
Old Oct 6, 2010 | 08:40 AM
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
I second the Lextech suggestion. I've only seen someone replace the needles once on their own, so I'm guessing it's pretty tough.
Old Oct 6, 2010 | 09:25 AM
kwg's Avatar
kwg
you can always buy a cluster from the junkyard
Old Oct 6, 2010 | 11:49 AM
1uzDreamSC's Avatar
1uzDreamSC
if you think your handy enough give it a try. I like fixing stuff myself, especially on my sc400 which im going to keep forever. So why not just get to know it inside and out.
Old Oct 6, 2010 | 04:26 PM
Exthultu's Avatar
Exthultu
Clusters from the junkyard along with Ac units have been in the sun constantly and will probably be worse. Check the DIY on cluster removal and lighting changes. If cleaning them doesn't work, just go with Lextech.
Old Oct 6, 2010 | 07:56 PM
Loo-10-ant's Avatar
Loo-10-ant
I just bought 2 clusters...50 bucks each off Craigslist...I made sure the seller was straight up about the needles and gauges...i didn't care about the bulbs. I did call Flow Lexus. Bulbs were $10.50 each. WTF?? Thas $80 for some 2 dolla bulbs...The H3LL man! I used the 74's worked just fine.. All the needles work too as the sellers stated.
Old Oct 6, 2010 | 08:43 PM
MattStarr's Avatar
MattStarr
Umm, they're 194's
Are there Lexus parts galore where you're from or something. Here in Denver, there's no such thing as a Lexus part in junk yard.
xiaolong
Oct 24, 2019 01:34 PM
gtstcactus
Dec 26, 2013 05:32 AM
Blaxxus
Aug 31, 2011 10:46 AM
Mr1uz
May 8, 2011 07:58 PM
HotBoy
Jan 3, 2004 10:32 PM
