brake upgrade
Old Jul 21, 2002 | 09:12 AM
ChronoJ1's Avatar
ChronoJ1
Default brake upgrade
I'm planning to upgrade my rear brakes to Supra TT brakes and just wanted to make sure whether these parts will do.
part number
- 90947-02745 Hose, Flexible (for rear RH)
- 90947-02745 Hose, Flexible (for rear LH)
- 47327-14030 Tube, rear brake, NO.2
- 47327-14040 Tube, rear brake, NO.1
- 04466-14040 Pad Kit, disc brake, rear (pad only)
- 04948-14010 Fitting kit, disc brake rear
- 47730-14270 Cylinder assy, rear disc brake, RH
- 47730-14280 Cylinder assy, rear disc brake, LH
- Drilled/Slotted rotors from SC400.com
Is there anything else I am missing?
Will these bolt on without problems?
Oh... one more thing... is it a possibility that the calipers can rub my rims (7.5 inch width) ?
Old Jul 21, 2002 | 03:11 PM
ACleanSC4's Avatar
ACleanSC4
Hey Chrono,
Let me know when you're ready for the Supra TT rotors.
Check the offset of your rims right now, I believe if they're 38+ in the front and 40+ in the rear, you should be ok. Supra Big Brake Guys, can you verify that?
Tony
Old Jul 21, 2002 | 08:09 PM
ChronoJ1's Avatar
ChronoJ1
I'm ready to get this thing done right now...
Just need to knwo were to get the parts.
For now...the only source is the Toyota dealer here in Ann Arbor.
But before I go ahead and buy these parts..I need to know if they will fit...
DRFT103
Apr 4, 2009 03:38 PM
lexforlife
Suspension and Brakes
94
Mar 30, 2005 11:42 PM
HKGS300
Jan 27, 2003 03:29 AM
Ag02M5
Apr 13, 2002 05:44 AM
