SEM or other plastic dye to change Black plastic seatbelt covers to Ivory?
I got tired of my cracked rear seatbelt covers and decided to replace them.
... with these, since Ivory or any other color is now unavailable.
I've read a bit about some owners using SEM plastic aerosol paints to change plastic interior parts to black but I haven't found much for going from Black to Ivory.
Has anyone had experience dyeing or spraying interior parts to an Ivory, Gray or Griege equivalent hue?
Nobody will see the underside. Check out somesthig called painters triangles or painter pyramids. They elevate the item you are painting by 1 inch and have a limited contact point with the painted surface. Good for the entire cover up.
I use the rear seats a lot, actually. One of the main selling points of the car was the usable backseats There are way too many 2-seater RWD options these days and not enough 2+2's.
The scratching is what I'm worried about. I hope you guys are right about SEM coating being durable. We'll see.
SEM is not dye. It's a coating on top of the part and will change from light to dark no problem. Like any coating, prep is key.
Wear gloves, follow the directions, and it will last. The durability isn't so great on the actual seat portions but on those plastic parts it will last. And when you do eventually scratch it, you can do it over again in the same color 5 years from now.
