SC Prothane Front Bushing Kit
Old Aug 20, 2010 | 05:55 PM
SEXY 400's Avatar
SEXY 400
Thumbs up SC Prothane Front Bushing Kit
Just want to tell you all I just got this kit installed and it did wonders to my ride quality. The adhesion and connection to the road is night and day with the new bushings. The old ones literally were gone. 2 Thumbs up for the kit and easy install by my mechanic.
Company: Prothane
Part #: 18-207-BL
Price: $66.98 out the door at JEGS
TIP: Be sure and call in to DOUBLE CHECK if its in stock
What you get: Complete FRONT upper and lower control arm bushings for both sides.
What it did for my ride:
1. Eliminated wheel hopping and shutter.
2. Increased adhesion and connection with road
3. Eliminated the famous CLUNK/Rattle sound going medium speed over bumps and dips.
4. Eliminated the unnecessary wheel arching when stopping and reversing.
5. Increased stability at all speeds
6. Increased camber correction which also made my wheels flush so thats a plus!
Negatives:
1. You will FEEL the road more
2. Alignment is needed after install!
Hope this helps some of you that are still fencing sides about replacing these little bastards that destroy the ride quality.
Regards,
Nick
Old Aug 20, 2010 | 06:14 PM
scENFORCER's Avatar
scENFORCER
Read somewhere that another downside is that they dont stay lubed very long, and you have to re-lube them about every year. Is that true?
Btw I've been meaning to pick these up forever, but I think I'll wait till I get my suspension done and do it all at once.
Old Aug 21, 2010 | 09:30 AM
SEXY 400's Avatar
SEXY 400
Depends on the amount of lube they use. I heard that too so just be sure and put A LOT of lubrication. If you don't trust the lube Prothane provides use something that you KNOW or have researched that won't dry up (Technically this lube is water proof and resilient to drying up) but who knows lol. So far so good for me and I drove in the desert for 500 miles so far. No problems. What it comes down to is if you lube it right or not.
Old Aug 21, 2010 | 10:58 AM
ArodDaLob's Avatar
ArodDaLob
i needa get off my lazy *** and do this. the ball joints are such a pita though..... did you do it yourself?
Old Aug 21, 2010 | 11:32 AM
BartleDoo's Avatar
BartleDoo
I left all of the ball-joints assembled when I did mine a couple of weeks ago. I just had the spindle and control arms on the ground hanging from the tie rod. I only did the lowers with prothane, but I don't think it would have been a problem to get the uppers, as well.
Old Aug 21, 2010 | 11:49 AM
vietunit's Avatar
vietunit
I'll buy a set soon and lets do it LOL, gonna be a long day.
Old Aug 21, 2010 | 12:52 PM
okbobbo's Avatar
okbobbo
Default Zirk fittings
My mechanic put Zirk fittings on before installing which should make lubing easy.
Old Aug 21, 2010 | 01:08 PM
scENFORCER's Avatar
scENFORCER
^ what are Zirk fittings?
Old Aug 21, 2010 | 01:29 PM
BartleDoo's Avatar
BartleDoo
That's a good idea. He just tapped them into the outer sleeves?
Old Aug 21, 2010 | 01:54 PM
megamax's Avatar
megamax
so do they have a full urethane kit for the sc(like a master kit) i looked on ebay but no avail..
Old Aug 21, 2010 | 02:23 PM
MIGS's Avatar
MIGS
i used to have the link for $66.98 kit at JEGS, but i lost it. Can you post up the direct link?
i need these bad..
Old Aug 21, 2010 | 02:35 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
I wonder how these compare to TM Engineering bushings? Thats what I did all of mine with and its night and day. Remember when you think you are almost done burning them out, keep burning! They are a pain to do, but the difference is amazing. Thats a very cheap price for all of them for the front.
Old Aug 21, 2010 | 02:42 PM
good2go's Avatar
good2go
Ha, That's what I was thinking too. How can you possible put a fitting to the inner sleeve
It seems to me this may not offer much improvement; you're still gonna need lube on the inner sleeve area, AND, most shops aren't set up with anything more than the regular grease for their guns, so .... what's the efficacy of the wrong kind of grease going to be with these poly bushings?
IDK, maybe it'll be fine just the same, just thought I'd throw in some considerations that came to mind.
Old Aug 21, 2010 | 02:55 PM
jintei's Avatar
jintei
Thank God I found a shop here in socal that can do it for $160 including the alignment!
Imma do this next week!
Old Aug 21, 2010 | 04:44 PM
aEO 37's Avatar
aEO 37
^^^ where is this? I did my lower passenger side and that made me decide to not do the rest my self. I still need to do the upper and and driver side control arms. Alignment is a plus!
