Trunk won't open
Old Aug 15, 2010 | 10:46 PM
saurah's Avatar
saurah
Question Trunk won't open
My trunk won't open, but the gas door pops open.
I removed the lock thing from my tan piece, and stuck it into the black piece. Prior to me JB Welding the rectangular gas lid/trunk/key hole thing in everything worked fine.
Wtf? Its not a fuse, obviously because the gas door opens. The plugs are in correctly, everything was fine until I messed with the locks. Heres the kicker, my key doesn't work for the trunk, nor does it work for the valet lock deal. It only works for the ignition. The valet thing doesn't appear to be pushed in/activated.
Hopefully this makes some sense...? I've never in my life had so many stupid *** problems working on any car.
Old Aug 15, 2010 | 10:50 PM
TomLee's Avatar
TomLee
I have the same problem. Gas cap opens, trunk never does. I thought it had something to do with the valet lock, but no luck.
Old Aug 15, 2010 | 10:55 PM
saurah's Avatar
saurah
Did you ever mess with anything? Or did it just stop by itself?
I have no way into my trunk.
Old Aug 15, 2010 | 10:57 PM
CrazySC300's Avatar
CrazySC300
Are you sure you guys have the master key?
Old Aug 15, 2010 | 11:00 PM
saurah's Avatar
saurah
I'm not sure.
The QP has been repaired, and I'm missing VINs in the drivers door, so maybe the trunk was replaced without switching the lock?
Old Aug 16, 2010 | 12:08 AM
TomLee's Avatar
TomLee
I just open the trunk with my key
Old Aug 16, 2010 | 06:23 AM
nfordhk's Avatar
nfordhk
The key for the ignition is not the same as the key for the trunk is how it came on some SC years. Also double checked your keyhole to make sure its not locked this can be unlocked with the same key as the ignition but is not the same key for the actual trunk keyhole
Old Aug 16, 2010 | 07:05 AM
SpiderN9NE's Avatar
SpiderN9NE
Post maybe
just maybe, but my previous SC did the same thing to a certain extent. but id play with it like a trick window switch and it'd work sometimes. if it failed i always used the key but i know you said yours doesnt work. i guess trying to pull hard or snap up the switch would be your best bet. good luck.
Old Aug 16, 2010 | 01:45 PM
scviolence's Avatar
scviolence
take off the bottom panel unplug the switch to the trunk opening switch get a paperclip stick one side on each side of black and blue wire plug...(pretty much making the black and blue wire touch) wa la...trunk should open...
Old Aug 16, 2010 | 11:52 PM
miraluna's Avatar
miraluna
check if the key hole is pressed down... use your master key to unlock it... you will know if you look down...
Old Aug 17, 2010 | 11:37 PM
saurah's Avatar
saurah
Figured it out. I need to make a little DIY so other people who fall in the same situation can figure it out. Took 3 days of searching, and more time messing with it, but I fixed it.
Old Aug 18, 2010 | 01:54 AM
vietunit's Avatar
vietunit
^ Nice, damn reminds me I need to make some spare keys and fix my trunk lock, gets loose after driving over bumps or w/e and I can open it by just pulling it -___-
Old Aug 18, 2010 | 02:10 AM
Cleanshots's Avatar
Cleanshots
convert to the trusty cable trunk latch..
Old Aug 18, 2010 | 05:57 AM
MIGS's Avatar
MIGS
Why don't you share with us exactly how to do that, sir
BigGoober
Sep 4, 2012 03:17 PM
SC Boss
Dec 4, 2008 03:25 PM
stokdd
Aug 6, 2006 10:33 PM
g2racer
Jul 17, 2006 01:12 PM
messysc
Dec 11, 2001 06:34 AM
