IIRC they're like $750 per set of two. You can pick upper vs lower, front vs rear, etc.
Another option is camber correction bushing kit. GL finding one, I have two sitting in some upper control arms now. Debating wether I want to install them or get less aggressive wheels. . .
I may have to order the adjustable rear upper arms pretty soon...Pricey, But I have no choice as the oem rear upper control arms for '95 year model SC's are no longer in production.
I'm running tcsportline, and I'd only recommend them if you're down to check them every other day or so to make sure the asian threads haven't come loose. Other than that, I greased the hell out of the bushings prior to installations so they haven't given me much trouble yet. pair can be had for ~$300. A quick search of this forum can show you what happens when these arms fail.
