removed distributor without marking...big mistake
hi... in need of help, while we was changing the water bypass o-ring, a friend removed the distributor without marking the spot so that we can install it as was..... i did try to realigned but it didnt start.... i did read a section here but somehow its not working...by any chance anyone have a clearer detail of how to put the distributor on? i got a supra manual and will look into it, but mean time.... any other ways to make it simple to fix....thankx
did you take the rotor button off as well or just the dizzy?
if you just took the distributor off i'd have someone move it around by hand a little while you try cranking it..
thank you so much..... i just remove the distributor off.. not the rotor...i will try that and yes i do understand ... if i have any other problem... i let you kno and let u kno what happen.... another problem im going to have is that his stock pulley came off.. and he replaced a aftermarket pulley for now til he can get more money to buy the oem or the titan. hope that aftermarket have a marking on it so that timing can be check.... we all learn our lesson.... they tot that it be like a honda... hahaha.. yea ight....big mistake.. but thanks again..
dont put a screw driver down your sparkplug hole use a mcdonalds straw, i believe alldata mentions that you can find TDC by looking through the oil filler cap and crank till the camshaft is pointing upward.
well... finally i got it running....it was tough but i manage to get it started... timing might be tad off but its idle smooth and run fine.... it just that there no marking on the aftermarket crank pulley so i ended up using the cams... but still not actuate..will have to find him a stock pulley or upgrade to titan....thanks for all the help.....
tunedis95
Feb 27, 2025 02:16 PM
facime
Jul 29, 2013 08:52 PM
