You definitely want to pull the coil wire off the distributor. Disabling the fuel pump isn't gonna do squat to eliminate the spark that's gonna be at the end of your plug wires... looking for something/one to bite while you're checking the compression. Kill the spark!
Pull the EFI fuse- no need to pull anything else. I've done this on an SC and supra for checking compression, works the same. DO NOT JUST DISABLE YOUR IGNITION. Your engine will flood with gas.
