aristo transmission problem
Old Jun 30, 2010 | 11:20 PM
soarer13oy's Avatar
soarer13oy
Default aristo transmission problem
Im having issues with my aristo transmission. After installing the transmission i was able to drive the car for a couple of days until it started to act up. After driving for a bit the car then slips as if the car is in neutral. After a while the car is able to drive for a block or two and then acts up again. I dont know if its my torque converter or transmission.
Old Jul 1, 2010 | 09:39 AM
soarer13oy's Avatar
soarer13oy
Does anyone have a spare torque converter i can test to see if its actually the toorque converter? Im in the sacramento area but will be willing to drive to the bay area.
Old Jul 1, 2010 | 11:30 AM
99SC42's Avatar
99SC42
How is you fluid level, that's the first thing i would check..
Old Jul 2, 2010 | 05:54 PM
fonzo's Avatar
fonzo
what type of fluid did you use?
Old Jul 2, 2010 | 11:29 PM
soarer13oy's Avatar
soarer13oy
toyota atf type iv. Fluid level is good and yes i did drive around let it idle and then check.
Old Nov 3, 2010 | 02:09 PM
AllenG's Avatar
AllenG
question for you on this...what did you do about the connector differences on the harness that plugs into the transmission?
Old Nov 3, 2010 | 04:18 PM
stockhatch's Avatar
stockhatch
He has an aristo engine and harness so it plugs right in.
Old Nov 3, 2010 | 05:06 PM
soarer13oy's Avatar
soarer13oy
^^^^Yup............
Old Aug 27, 2013 | 02:30 PM
alvinguy's Avatar
alvinguy
did you ever find the solution for this? my car is doing the same thing... sc3 with aristo 2jzgte and auto tranny.
Old Aug 27, 2013 | 10:13 PM
soarer13oy's Avatar
soarer13oy
Transmission was bad. I swapped the trans with another transmission and it ran great.
Arch11b
Performance
Sep 4, 2024 06:20 PM
gcam77
Sep 10, 2022 05:05 PM
SC3NAT
GS - 1st Gen (1993-1997)
Aug 4, 2013 03:46 PM
slappy96
Mar 10, 2012 08:30 PM
AllenG
Nov 3, 2010 02:21 PM
