BoostCreep
Old Jun 23, 2010 | 07:44 AM
SC51's Avatar
SC51
Default BoostCreep
Been having this issue after I put the slightly smaller turbo on, I like it, spools so fast that I think the WG can't dump enough air? Manuals shifting the car it holds boost at 10 where I set it for couple seconds but as the RPM's get higher the boost climbs as well. And putting it straight to the floor in auto mode the car screams and blasts up to like 15 so I just let off. Not fun. Only solutions I can see is bigger waste gate any suggestions?
Specs:
Stock motor/ head gasket
T70 turbo w 68a/r exhaust
44mm WG
Halmen MBC
Old Jun 23, 2010 | 07:56 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
is this with the manual boost controller?
Old Jun 23, 2010 | 03:35 PM
StiCk3's Avatar
StiCk3
Halmen MBC (manual boost controller). That's probably the source of your problem right there. What's the wastegate spring rated for?
Old Jun 23, 2010 | 10:08 PM
SC51's Avatar
SC51
Ya I am running a boost controller to prevent the WG from opening so fast. The Spring is rated for 8lbs or so.
Old Jun 23, 2010 | 10:59 PM
madmax98's Avatar
madmax98
Did you try adjusting the controller to yield less boost?
Old Jun 24, 2010 | 05:08 PM
SC51's Avatar
SC51
Yes I have tried adjusting it. Mabe my WG is not good enough for running just 10lbs.
Old Jun 25, 2010 | 12:33 AM
madmax98's Avatar
madmax98
What happens when you adjust it?
Old Jun 25, 2010 | 07:53 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
try removing the boost controller and see if it holds off the spring.
if so then its the boost controller, if not its the gate.
Old Jun 25, 2010 | 07:45 PM
SC51's Avatar
SC51
Ya ive tried disconnecting it and cars way slower wastegate opens instantly and the boost still creeps up quick, so quick that ive spike to 15-16psi range the other night now im seeing white smoke after it comes down from a rev, it idles a little different but it spools way smoother. I take it i blew the head gasket a bit
Old Jun 26, 2010 | 03:56 PM
SC51's Avatar
SC51
**update** The smoke is bluish too, also when I start my car up it'll turn over and make like a skip sound then start like the ignition skips once then starts
Old Jun 28, 2010 | 12:59 PM
S142jz's Avatar
S142jz
Blue smoke could be too much fuel or antifreeze.
Do u know what ur afr's are on and off boost ??
Old Jun 28, 2010 | 01:59 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
does it feel like the starter is kicking back (it should sound a little violent if it is). usually a sign that the ignition is too advanced. what kind of management are you running? have you messed with the distributor lately and did you remember to reset the base timing after?
Old Jun 28, 2010 | 02:15 PM
cartmill's Avatar
cartmill
need more details of setup
Old Jun 28, 2010 | 02:18 PM
99SC42's Avatar
99SC42
Ali he has a GE VVTi dosn't have a distributor.
What Brand WG are you running?
What kind of Vaccum line are you using on the WG?
Old Jun 28, 2010 | 06:50 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
oh forgot he has vvti, if your turbo is spooling real hard you may need a bigger/better wastegate. I have no problems holding 9 psi with my xspower t61, I only have a 40mm hks style gate but it dumps pretty loud though.
Its not too efficient to run big turbos at low boost, you may want to consider a TT headgasket and running more boost or If you are running stock compression for a long time using a smaller turbo which will spool quicker.
Felts
Jun 28, 2020 08:13 PM
scsexy
Apr 8, 2020 09:01 AM
6SOARER
Apr 28, 2014 12:42 PM
SCereal
Feb 11, 2014 06:06 PM
ddrsquad
May 18, 2011 02:16 PM
