Need a little help with black taillights
I tried blacking out 1 97 tail. its not as easy as headlight for sure. Actually got it from king luis that posted up there^^^
If you plan on doing it, be careful not to get water on the chrome parts. They are known to flake off somehow. Also on the passenger side light, becareful with the key hole part when separating. Some people have cracked the lens assembly.
I would want to just red out the amber, but im too scared.
when i did my tails on my truck. i just grabbed some transparent window tint and clear coat from hobby lobby. taped off and coverd the surrounding areas then went to work with the tint. let them dry for 5mins, then went with another coat. after 3 light coats, i got a deep burgandy color instead of black. more coats woulda got them black though. i hit them with clear coat them drove around for a almost instant dry. idk any other alternative way except for buying the cover. so hope i helped. good luck
here ya go. but like the others said the 97 passenger side is a little complicated. i broke mine and had to buy another. but after i finished i think its was still worth it.
https://www.clublexus.com/forums/sc-...cs-inside.html
If you do smoke/paint them, do it very very lightly
I used to have my (92-94) tails done almost as black as my car, looked ok but to much of a hassle to deal with cops so often.
Re did it lighter and much happier.
Pogophil
RX - 1st Gen (1999-2003)
Dec 24, 2005 10:24 AM
