Do not change ur fuel filter!!!!!!
#78
Disconnect the line from the fuel pump
Everyone keep in mind it's easy to change ur filter but when their is a chance for things to go the wrong way they will.
So if ur going to change ur fuel filter do it only when you have about 1 or 2 gal. In the tank.
Reason being: the fuel lines are soo close together that if you don't thread the fittings correctly the. You will be fighting with them for a while. That isn't the bad part.
When you have gallons of fuel running down ur arms and getting burnt from it I where the big problem is.
So now I'm stuck waiting for hours for this fuel to run out. Dame toyota for being so stupid putting these lines so close
joewitafro (05-17-21)
anarchyx34
14
07-19-12 07:33 PM
