hello everyone, im having a problem with my windows.
my passenger side window roles up verry slowly when i roll that and the driver side up at the same time.
but the driver side window roles up fine other than a loudy creaky noise when rolling it up.
and when i let go of the driver side window switch the passenger side rolls up a little faster.
I bought a new regulator to fix that on mine and it's not the regulator. I unbolted the window and the motor runs normal. I believe the tracks on the outside are what is messed up because the window gets stuck with it unbolted. Haven't had a chance to take it apart and see whats in there.
Appreciate all of you guys time in getting back to me. Just had a ton of work done to it and this BS was the only thing we couldn’t get right. Lol!
We did figure it out though!!!!! So we were doing the sequence doing the driver then around the car one door after another as everyone mentions. However, turns out the sequence in my 06 for whatever dumb reason is the driver door, then the SUNROOF then pass rear pass and driver pass. Why use logic!?!? Straight dumb! We good though!
Appreciate all of you!!!
Err... are you referring to a 2006 model Lexus with slow window up/down issues?
This old thread refers to such issues in 1992-2000 SC300/400’s.
