brakepads and rotors replacement
Old Jun 17, 2010 | 01:38 PM
Avarec's Avatar
Avarec
Default brakepads and rotors replacement
whats up guys
where do you guys order you're brake pads and rotors from?
id like to get decent quality ones at pretty good deal if possible
Old Jul 1, 2010 | 06:17 AM
lisc300's Avatar
lisc300
I get my stuff from boosted performance inc,try there website
boostedperformanceinc.com
Old Jul 1, 2010 | 11:06 AM
imDementeD's Avatar
imDementeD
i went to napa for my rotors 30 bucks each then ordered my brake pads from r1 concepts..6x.xx + shipping for axxis ultimate pads
the rotors are already installed just waiting for the pads before i can leave feedback on how they worked out
Old Jul 1, 2010 | 02:21 PM
dwebb99's Avatar
dwebb99
rockauto.com, all around great place to get parts...
Old Jul 4, 2010 | 05:09 PM
Shanty's Avatar
Shanty
I went with R1 drilled and R1 Ceramics and they were affordable and have worked awesome thus far.
Old Jul 4, 2010 | 10:19 PM
SChema's Avatar
SChema
If you drive on the street and don't push your brakes you can get your parts at any local store. I've had good luck with Wagner Thermoquiets, low dust and minimal squeaking, if any.
Old Jul 5, 2010 | 07:12 AM
matrixgts's Avatar
matrixgts
Try place for brakes.com
Old Jul 9, 2010 | 12:40 PM
Avarec's Avatar
Avarec
thanks guys,
Old Jul 12, 2010 | 09:10 PM
lev00221's Avatar
lev00221
You should probably be consistent with the company you buy the parts from. What I mean is that I used OEM pads with Wagner rotors and the combination is noisy. I am not sure what the difference is in materials but I have never had a noise issue when I use only OEM parts.
Old Jul 15, 2010 | 06:12 PM
bspecmr2's Avatar
bspecmr2
So far I've only used Toyota brake pads. They have minimum brake dust and stop well both when cold and warm. I have not experienced any fading while street driving. Unless you take your car to track events or auto cross there is no need for more expensive brake pads or rotors.
I've used Napa rotors with success on my stable of prior Toyota vehicles. If you want to keep it quiet, use OEM pads. I advice against race application pads use on the street. The general rule is that race pads are designed to be used when properly warm. That can be achieved on the track, but not in street application.
Axxis metal masters give off a lot of brake dust and wear down rotors quite fast regardless of driving style. On a rear-heavy 1st generation MR2 I used a combination of EBC green stuff pads on the front and axxis metal masters in the rear to correct the front brake bias. This is not necessary on the Lexus. EBC pads were very high quality and gave off no noise. Shop around for best prices.
stevelifts
May 25, 2022 08:25 AM
Stemmer
RX - 1st Gen (1999-2003)
Mar 14, 2022 06:04 PM
Neofate
Mar 25, 2011 02:49 AM
912inc
Mar 20, 2007 08:11 AM
LEXITT
Suspension and Brakes
18
Mar 18, 2006 05:12 AM
