Lowering spring question
Old Jun 3, 2010 | 09:13 PM
meangreen1's Avatar
meangreen1
Default Lowering spring question
Wanted to know why people thought were the best spring? Tanabe NF210 Springs? Also, if ordering supra springs, will it give me more of a drop then ordering springs for a sc300? Didn't find this info while searching. I DONT want struts just springs.
Old Jun 3, 2010 | 09:23 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
If you use supra struts, which will give a slight lower stance, maybe 1 inch or so, then you will have to use the supra springs. You cant use supra springs on your stock or oem factory replacements on your 300. If you use Tanabe they will give you 1.2 inches in the front lowering and approx. 1 inch in the rear. I would suggest repalcing all of your struts and strut mounts if you lower your SC. JMO. This will give you a better ride all around and not where out your factory stuff.
If you use Eibach 1 inch all around, on stock struts
If you use Esplier springs, 2 inch in the front and rear approx. on stock struts.
Let us know what you decide and I hope this helps.
Old Jun 3, 2010 | 09:42 PM
meangreen1's Avatar
meangreen1
Yeah I am torn. I want coilovers, but can use the 1100 for exhaust and springs + a couple of other goodies. What to do, what to do. Maybe I can find a smoking deal on used springs and struts.
Old Jun 3, 2010 | 09:49 PM
t70 supra's Avatar
t70 supra
do not get the nf210 i had them they are straight garbge. they dont drop the car at all only reason i bought them cause the guy gave me a good deal. i am sorry i understand what u mean buy i would just buy coilovers man i promise once you get them u wont slap your self. best buy you can always get an exhuast
Old Jun 3, 2010 | 09:58 PM
meangreen1's Avatar
meangreen1
Yeah true. Just want everything now!!!! I had JiC A2's on my WRX and loved it. Just putting a feeler thread out there.
Old Jun 3, 2010 | 11:10 PM
jjffyy's Avatar
jjffyy
If you want the lowered look of coilovers but doesnt put a hole in your wallet then your best bet would be to go with the Espiler ASD springs. 2 in drop around and sometimes they can be found for sale on the classifieds here.
Old Jun 4, 2010 | 11:41 AM
scENFORCER's Avatar
scENFORCER
I'm in the same situation as you are, I'm having touble justifying speding $1100 on coilovers when I can just get the Supra suspension. But everyones telling me its totally worth it..
Old Jun 4, 2010 | 11:48 AM
Biggu's Avatar
Biggu
buy the coilovers, your car will ride a **** ton better then on just lowering springs.
Old Jun 4, 2010 | 10:35 PM
NineTreSc3's Avatar
NineTreSc3
you wont regret a set of good namebrand coilovers. but stock sc front struts work with supra springs. Rear struts must be supra. I had tanabe gf210 and immediately wanted coilovers. Springs were too bouncy. Bought cheap coilovers and they were still better than the springs.
Old Jun 6, 2010 | 09:29 PM
SChema's Avatar
SChema
Bought my car with the NF210's previously installed and immediately wanted coilovers. I was in the same boat, couldn't justify spending 1500+. I waited for about a year before I got my set-up. Just wait if you can, a deal is bound to be around the corner eventually.
Can't beat the adjustability of spring rate and dampening of a set of coilovers. I must say after getting a set, I will never lower a car with springs again.
Peterngu3
Suspension and Brakes
Dec 31, 2019 11:48 AM
ChadsGS400
Feb 6, 2016 09:12 PM
Cranbery
Jan 12, 2012 08:53 AM
titesi
Aug 11, 2005 08:10 PM
EUROJulian
Jun 26, 2004 06:17 PM
