Dropping on springs
Old Jan 7, 2012 | 02:25 AM
Cranbery's Avatar
Cranbery
Default Dropping on springs
So I'm looking to lower my sc300 on springs like an inch and a half. I don't ever plan on going lower than that so I didn't think investing in coils was worth it. I'm wondering if lowering on springs is a better alternative for just a 1.5" drop? And what spring brands are a good fit for the sc. I could lower on coils, but if I can save and accomplish my goal on springs I would. And springs are pretty easy to install if I'm not mistaken?
Old Jan 7, 2012 | 07:56 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Springs are easy. To get the 1 and inch drop that you are after, I would suggest getting the TT struts and those lowerings of any brand. How deep your pocket are is the spring that I owuld go with. The TT struts will lower the car a mere inch, then the spring will do the rest. You cant mix and match springs and struts from the SC to TT.. Must use TT stuff all together, and SC stuff all together, no swapping.
if you want to use the struts from the SC, go with Tokico blues and Esplier springs, if you can find them. Tanabe and Eibach give a moderate drop, around an inch or so, but the Tanabe a slight bit more in the front. The choice is yours and GL..
Over and OUT!!
Old Jan 8, 2012 | 11:35 PM
BLK13X's Avatar
BLK13X
For Mind Cruising
I'd still change the shocks while it's all out, you might as well instead of having to change it within a year of driving.
Old Jan 12, 2012 | 08:53 AM
cheddarSC4's Avatar
cheddarSC4
ive also been wondering about TT setup and it was answered so thank you
ChadsGS400
Suspension and Brakes
Feb 6, 2016 09:12 PM
300ZXSC300
Mar 12, 2012 06:40 PM
meangreen1
Jun 6, 2010 09:29 PM
tritron
Apr 27, 2008 07:18 PM
aftv
Feb 19, 2007 12:20 AM
