SC- 1st Gen (1992-2000)
little bit of help with audio setup
Old 05-21-10, 12:43 PM
czar07
czar07's Avatar
Default little bit of help with audio setup
hi all ive been thinking about upgrading my audio setup so this is the stuff im thinking about
Head unit:http://alpine.com.au/showItem.php?item_id=37
sub amp:http://alpine.com.au/showItem.php?item_id=71
speaker amp:http://alpine.com.au/showItem.php?item_id=79
sub:http://alpine.com.au/showItem.php?item_id=102
fronts:http://alpine.com.au/showItem.php?item_id=83 (or the 5.25" ones if these are too big)
rears: not to sure what i should be running for the rear speakers? components same as fronts?
the fronts and rears should be 4x100wrms @ 4ohms. the amp is 4x100wrms @ 4 ohms. i assume this should be a pretty good match.
sub is 1000wrms @ 4ohms and sub amp is 1000wrms @ 4ohms
this is what i THINK it would be...
the head unit has three pre amp outputs. should be using two and run crossovers for both? i.e the 1st one will be highs and mids for front+rear speakers and tweeters, and 2nd one will be for lows for the sub. i am quite confident with doing the power wiring, but the audio stuff not so much. am i running the amps the right way? do i even need crossovers before the amps?
Old 05-22-10, 09:42 AM
1uzDreamSC
1uzDreamSC's Avatar
no need for the crossovers before the amps
the mono-block should have built in crossovers and a high-pass filter/subsonic philter. so no need there.
before the 4 ch amp you could add an equalizer but that is not necessary either.
the rear speakers do not have a separate tweeter so if you want one your gonna have to add one
Old 05-22-10, 12:02 PM
czar07
czar07's Avatar
yeh i figured that after reading through some more details on the webpages. decided to stick with 6x9s for the back.
Old 05-22-10, 01:56 PM
jegMAN
jegMAN's Avatar
your system is gonna bump. rears are optional and is just filler. fronts are what u only need for the ideal soundstage, but seeing how u got money to blow go for itt
vital
03-26-18 10:45 AM
Baby ///M3
06-13-14 05:09 PM
repetedb
06-03-10 08:04 AM
abobiznow
10-06-09 07:51 AM
silv-SC
08-12-05 09:23 AM
Quick Reply: little bit of help with audio setup
