Lower Control Arm ????????
Old May 12, 2010 | 01:34 PM
tyacrzy's Avatar
tyacrzy
Default Lower Control Arm ????????
Does any one know if putting the Toyota Supra lower conrol arms would be a upgrade in any way or do they even fit. Thank you
Old May 12, 2010 | 01:39 PM
Sup2jzgte's Avatar
Sup2jzgte
A bit stiffer, but if you wanna know all about it then type in "Supra control arms" into the SEARCH feature and you will have all your questions answered
Old May 12, 2010 | 04:47 PM
good2go's Avatar
good2go
Are you referring to the NA or TT Supra parts ??
The NA is identical to SC's, whereas the TT's is a lighter aluminum alloy if I'm not mistaken.
Of course, this information is all readily available by using the search function
Old May 22, 2010 | 12:26 AM
SC1984's Avatar
SC1984
They fit and are cheaper than lexus lower control arms.
Old May 30, 2010 | 12:15 AM
DA51's Avatar
DA51
Default front suspension replacement
I'm in the middle of replacing the front components. I got new upper and lower control arms; new tie rod ends; new sway bar links; new motor mounts and transmission mount.
Well, my 92 SC400 with 154,000+ miles and living in the Snow Belt I've ran into a bit of RUST!
The right rear bolt to the LCA is frozen.
I don't have a Torch. My Diamond grit blade is cutting the harden steel bushing. Should I just try to cut off the bolt and order a new one?
Any suggestions would be great!
Attached Thumbnails Lower Control Arm ????????-img_0111_640x480.jpg   Lower Control Arm ????????-img_0117_640x480.jpg   Lower Control Arm ????????-img_0125_640x480.jpg   Lower Control Arm ????????-img_0128_640x480.jpg
Old May 30, 2010 | 02:08 PM
madmax98's Avatar
madmax98
damn, any updates?
Old May 30, 2010 | 03:32 PM
rwdanthony's Avatar
rwdanthony
why not just cut the cam bolt. and replace it, if you cant buy a new one, just get one from a junk yard. or aliga, etc.
Old May 30, 2010 | 10:46 PM
DA51's Avatar
DA51
Default lower control arm
I called my friend who has a bunch of tools.
We tried a 12-ton Press, but that didn't work.
Then he brought out his Torch and heated the bushing to Red Hot and I pounded on the nut. It didn't bunge.
So I asked him to cut off the bolt/bushing and I would get a new one.
He brought out his 220 volt Plasma cutter and that did a quick job.
Since the Supra LCA part fits my Lexus, I imagine the cam bolt is the same for both vehicles.
My local Toyota dealer might have one in stock.
Both back cam bolts were rusty, but the fronts look near new., crazy.
Attached Thumbnails Lower Control Arm ????????-img_0160_640x480.jpg   Lower Control Arm ????????-img_0162_640x480.jpg   Lower Control Arm ????????-img_0164_640x480.jpg   Lower Control Arm ????????-img_0141_640x480.jpg
Old May 31, 2010 | 05:08 PM
dwebb99's Avatar
dwebb99
Generous applications of PB Blaster over several days/weeks may help in the future with these rusted bolts/nuts
Old Jun 1, 2010 | 10:29 AM
good2go's Avatar
good2go
wow....note to self: good reason to buy a car from CA, AZ, TX, etc.
Old Jun 3, 2010 | 01:12 PM
DA51's Avatar
DA51
PB Blaster does not work for buried rust. That is why I cut slots in the bushing trying to get PB deeper inside.
The solution is a new Camber Kit-back, just $11.64.
The LCA Cam bolts are different. The fronts are longer.
Old Jun 3, 2010 | 01:27 PM
DA51's Avatar
DA51
photos did not upload.
I'm waiting for the Camber kit, ordered it from Lexus.
Attached Thumbnails Lower Control Arm ????????-img_0123_640x480.jpg   Lower Control Arm ????????-img_0245_640x480.jpg
Old Jun 3, 2010 | 02:15 PM
good2go's Avatar
good2go
wait...are you saying Lexus sells a camber kit for the SC's?
Is this just the stock hardware sold together as a "kit" or is this a CORRECTION kit?
Old Jun 3, 2010 | 07:16 PM
rwdanthony's Avatar
rwdanthony
^^^ oh would i like to know as well!
correction kit as in for us lowlows who cant get back to spec alignment on stock adjustment bolts.
doozy
Apr 15, 2016 12:52 AM
SC510
May 27, 2014 07:00 AM
Soloist
Jan 9, 2012 02:42 AM
nefariousd
Jun 29, 2009 09:49 AM
SDSC300
Jul 8, 2002 07:53 PM
