My ´97 SC400
Subscribe
Jan 14, 2023 | 12:20 PM
  #421
The 3rd gear and the 2nd shaft is replaced, on monday comes the reverse gear and the 5th gear back on place and bring it back in the housing.
The pressure line is now a dash04 line. before, i had a dash03 line. i hope, this upgrade eleminate the very short time of shifted close the clutch (sorry for my bad english). the place for the fluid to come back, after remove the foot from the clutch pedal, was to small and the clutch closed not in 1:1 time. every time a part of a second shifted. i read in many forums and i think, the too small line is my problem. original comes the kit from 1UZswapkits (years ago) with a Dash04 main line and a Dash03 bleedline. But at this time, the was no infos to the correct size from the dealer (long story.... )
adapter dash03 vs dash04
dash04 adapter installed
time to open the gearbox
Reply 0
Jan 14, 2023 | 12:26 PM
  #422
remove the 5th gear and the output shaft bearing is every time a pain
3rd gear and 2nd shaft new and back in the centerplate.
greets
Tom
Reply 1
Jan 16, 2023 | 08:10 AM
  #423
Tom - I've ALWAYS loved your car and your upgrades are always very well thought out. Love seeing the transmission torn apart and I look forward to seeing more progress!
Reply 0
Jan 16, 2023 | 07:10 PM
  #424
Tom-- Thanks for the pictures and info on that Greddy center vent mount!
A "VSM" style mount is a plate made for a specific vehicle with a universal mounting area for any accessory that uses the "VSM" standard.
They may or may not still be available now but here's a thread on a couple of VSM style SC/Soarer specific mounts with pictures:
https://www.clublexus.com/forums/lex...300-400-a.html
I know it was a pain to do this rebuild on your transmission but VERY nice work! And that workshop space you've got handy-- wow!!
Reply 0
Jan 19, 2023 | 07:07 PM
  #425
What an exceptional (and long lived) build. I love it! Keep up the great work.
Reply 1
Jan 23, 2023 | 12:16 PM
  #426
thanks guys for the compliments
the last days, i had time to finish the gearbox. cleaned all threads and bolts, removed old sealant and cleaned the parts.
its a little bit tricky to mount the front housing. it needs much attention of the first gear/sync parts to have no space between. i removed 2 times the front housing, because the bearing was to much outside of the front.
but at least, a small turn on the input shaft and a move on the shift fork, and the shaft was in the correct high to fit the retaining rings.
yesterday, the last parts onbolted on the housing. the new dash lines in -03 and -04 also installed.
yeah! ready to bring it back in the SC chassis
the last thing to do is, to close the holes from the lines with sealant.
i hope, i have this week time, to install the box
greets
Tom
Reply 1
Jan 23, 2023 | 06:29 PM
  #427
Great work Tom!! That is one very clean gearbox restoration!
Reply 0
Feb 7, 2023 | 01:59 AM
  #428
Thanks!
In thelast days, i changed the to short bolts for the thwowout bearing plate. the thread in the alloy was not good, also longer bolts (M10x1,25 from 45-55mm, 38Nm torque), now its ok and all bolts are tight. on friday, we installed back the gearbox, and bleeded the clutch lines. now, the inputshaft is correct in the pilot bearing i´m happy. driveshaft installed at last and i wait for a warm day to bleed the clutch system complete and adjust the pedal. now we have all over the day under 32°F and this is not funny to work.
And the AEM wideband sensor is now connected to the gauge.
greets
Tom
Reply 1
Feb 7, 2023 | 12:41 PM
  #429
Tom - awesome progress! I sure do love this thing. Can't wait to see it back on the road when the weather gets better!
Reply 0
Feb 7, 2023 | 09:07 PM
  #430
It's going to be a pleasure for you to be able to enjoy your car again once the weather warms up again, Tom! Awesome and thorough work as always!
Reply 2
Feb 22, 2023 | 05:57 PM
  #431
HY!
On monday, i had time for a short trip with the SC. All gears are fine, no bad sound, no vibrations! The AEM wideband works fine, only the greddy informeter can not illustrate correct the value from the AEM gauge. i can adjust in the informeter the the value for 0V and 5V but the work not correct. maybe the wiring have a ground problem or the x-uego is not compatible to my oldschool gauge. the old wideband have other voltage steps for A/F from 0-5V. The x-uego goes 05-4,5V with different A/F values compared to the old gauge.
After the 20 miles trip, i checked the car from the underside and found a little bit oil on the propellershaft. i think, i used too much oil if i installed the shaft i cleaned the area and the shaft with break cleaner. the next trip will let me know, whether the oil seal is bad. i hope everything is okay.
Reply 3
Feb 22, 2023 | 06:43 PM
  #432
Pinion seal is seeping.
Your car is gorgeous.
Reply 0
Feb 22, 2023 | 10:45 PM
  #433
Tom, congratulations getting it back on the road again!!
Agreed with LeX2K: Sounds like the rear transmission seal at the propshaft entrance is leaking. Easy to replace. And... your SC400 looks fantastic!
Reply 0
Feb 23, 2023 | 06:40 AM
  #434
Tom I just adore your car - something about a V8 manual coupe just does it for me (don't tell anyone, but there's days I'd almost rather have a nice big N/A V8 instead of my 2jzgte). Keep enjoying that beauty!
Reply 0
Feb 24, 2023 | 06:36 PM
  #435
Hello!
After a 25 miles trip today, i checked the seal again and no oil more. i used only to much oil for the pinion when essembling. i´m now happy, all works fine, the clutch works like original
today i tested up to 100mph, this was not possible before, the car vibrated until the end of acceleration.
Time to get polish the car, remove some small dents and clean the interior for the season 2023
Reply 2
