97+ housing connector issue/alternatives?
Old Apr 21, 2010 | 12:34 AM
scshinobi's Avatar
scshinobi
Default 97+ housing connector issue/alternatives?
i have the housing connector but i dont have the part which plugs into it. in other words the positive and negative that go into the plug which then goes into the housing connector from the housing connector you have the ground and then positive so the h3 bulb can plug in. my issue is i tried to run it with out the part which it plugs into and keep blowing fuses so im guessing it works as a relay of some sort any way around this? if not anyone know the part number so i can order another
Old Apr 21, 2010 | 10:02 AM
Dx3's Avatar
Dx3
WOW! That was confusing... Maybe you should mention to begin with that you are talking about your foglights... Would make much more sense.
So you have the female connector for the foglight harness but not the male side?
Search for a thread I started about the 97 parts breakdown. On the 3rd page someone posted the link to buy the connectors. Hope this helps,
Jonny
Old Apr 23, 2010 | 11:26 PM
scshinobi's Avatar
scshinobi
so i went and bought one with 2 wires for $22 from toyota.... still blowing fuses. i might add my ground is longer than 12" im not an electrical genius, could this be causing the problem?
CleanSC
Jan 22, 2016 11:57 PM
ChronoJ1
SC400 / 300 Classifieds
Jul 28, 2007 07:21 AM
mi89325
Sep 1, 2006 03:13 PM
Brad0614
Jul 6, 2004 09:16 AM
prjctSC300
Mar 10, 2004 08:09 PM
