Soarer Torsen Differential
Old Apr 11, 2010 | 10:20 AM
monsterfac's Avatar
monsterfac
Default Soarer Torsen Differential
hey there club Lexus, I'm a owner of a sandstorm beige sc4
i recently got my dreaded rear clunk diagnosed, and it turned out to be my diff.
My question is: Is the JDM Toyota soarer differential unit swappable with my factory open diff?? i'm looking to change the whole pumpkin and not just the gears inside
Thanks alot
-matt
Old Apr 11, 2010 | 10:02 PM
5sp_jzz30's Avatar
5sp_jzz30
whole pumpkin will bolt right up. it should be the same diff as the na mk4 supra with lsd option and same as the mk4 supra turbo auto.
only different, big, diff was the mk4 supra turbo 6spd.
all other toyota torsen lsd are same aka aristo, soarer, na mk4 supra, mk4 supra turbo auto.
Old Apr 11, 2010 | 10:09 PM
monsterfac's Avatar
monsterfac
thank you for the clarification
Old Apr 16, 2010 | 03:51 PM
monsterfac's Avatar
monsterfac
another quick question
will i need any other parts beside the differential itself to do a torsen swap?
Old Apr 17, 2010 | 08:05 AM
spdrcr771's Avatar
spdrcr771
if your just changing the open diff to the torsen, not the hole diff (housing) then you might need shims for the lsd to set the backlash right.
Old Sep 17, 2011 | 08:10 PM
mdmaniac's Avatar
mdmaniac
I'm looking for a whole torsen diff & case unit. Does anyone know where I can find these reliably?
Old Sep 17, 2011 | 09:52 PM
Vwpride12's Avatar
Vwpride12
Car-parts.com. Try and find something with lower mileage
Old Sep 18, 2011 | 02:03 AM
mdmaniac's Avatar
mdmaniac
car-part.com doesn't seem to have any available Torsens. I did search for 1997 TTSupra A/T (should come up with the right one) but no parts
Old Sep 23, 2011 | 02:29 AM
KahnBB6's Avatar
KahnBB6
It's difficult to find one of the USDM TT Auto Torsen T-1's but they do come up for sale on Supraforums. You have to be very diligent-- i.e.: check the classifieds every hour until you get lucky. I'm not kidding. They really do show up and sell that fast more often than not.
That, or just put up a WTB ad there and wait patiently, which is what I eventually did.
The compatible LSD's from Soarers are Torsen T-2's. They are much rarer, sought after (in Japan at least) and generally cost more than your average whole TT Auto LSD pumpkin.
If it's a specific gear ratio you are interested in, you can always have a reputable diff shop swap in the ring and pinion ratio you want.
Good luck.
2JZ4lyfe
SC400 / 300 Classifieds
Aug 19, 2016 10:19 PM
1985zcar
Jun 6, 2008 09:13 AM
desol11
Apr 12, 2008 09:23 AM
Sc1UZ-FE
Apr 24, 2007 03:56 AM
