Push Button Engine Start
Old Aug 25, 2010 | 05:21 AM
  #46
Li Ls4's Avatar
Li Ls4
Damn I deffinatly want to do this in my sc
Old Aug 25, 2010 | 05:21 PM
  #47
gifford546's Avatar
gifford546
so I came across this today...
http://www.auto-hub.com/stardrive_pu..._ignition.html
this is the same system used in the Nissan Altimas. There is no need for a key which seems to be everyones main problem with this setup. The price is pretty steep, but I am definitely considering it.
Old Aug 25, 2010 | 08:19 PM
  #48
Cleanshots's Avatar
Cleanshots
omg omg omg new boy found good **** i know what im buying next!!
Old Aug 25, 2010 | 08:23 PM
  #49
sadwafair3's Avatar
sadwafair3
cut the starter wire in half to start with. now take the car side of the cut wire and put it on the 87 side of relay.make 30 constant 12volts.make 86 a negative ground.make 85 ignition feed.this will make your button work only with the key in the run position.no key no start. now.Now also i have a way where the same way as above but like newer cars using the brake pedal.using another relay make 30 and 86 negative ground.find the wire that turns positive(12volt) when brake pedal is pressed down.note;this wire should only turn 12 volts positive when brake pedal is pressed down and should turn off when released............make that wire once found to 85 on relay #2.now make 87 out which will be your new ground(negative)out to the first relay you built.remember to disconnect relay#1 ground as relay#2 is replacing its ground.hit me back and tell me it worked out just fine.later
Old Aug 25, 2010 | 09:05 PM
  #50
gifford546's Avatar
gifford546
haha thanks. I found this after someone put it up on a grand prix forum. I would like to look into the feasibility of replacing the ignition (key hole etc.) with the button to give it a much more factory appearance and to replace a useless key hole. I think it would look great replacing a useless vol **** too though.
gpxluke
CL Vendor Products for RC-F
66
Apr 16, 2017 11:33 AM
gpxluke
Feb 17, 2017 11:48 PM
netcbc
RX - 3rd Gen (2010-2015)
Aug 27, 2015 12:57 PM
YeA 2jZ
May 26, 2010 10:52 AM
jayz250
Mar 4, 2009 04:45 PM
