Engine Code 21?
My check engine light came up today after I turned on the AC full blast due to the high heat today in central Cali. I haven't turned on the AC in nearly a year. The code came out to be 21 after I shorted pin E1 and TE1. Anyone with a manual who can give insights into what this code means?
MrGQ
93 SC300
02's are supposed to be part a regular maintainance, my car has 156k on it, so i expect the 2 main heated 02's to go bad also.
test your 02, or just swap it, but for the time being reset your ECU and see if it lights up again.
and if your car feels funny, has less power, and/or shifts funny its cus your check engine light is on, i believe the ecu sends the car into a defense mod, and detunes it.
good luck
Xavier
It was pretty hot when I crank on the AC and I was speeding out to the freeway as well. According to the chart that hwallen172 posted, the conditions do match what was described. So could this be a one time problem that my car was experiencing under heavy load? Should I reset the check light and see if it comes on again or do I have to change out the front O2 sensors to prevent further damage?
MrGQ
