Unable to get a code
Old Feb 27, 2009 | 11:03 AM
campoida's Avatar
campoida
Unhappy Unable to get a code
1996 es300 -check engine light turns on, but mechanic unable to get a code. The car first has extremely slow accelleration even when the pedal is all the way down then it kills. wait about 30 min. and driving great again and no check engine light, however, you turn the car off and on again and the check engine light turns on and the symptoms are there again.
Old Feb 27, 2009 | 03:32 PM
donnie boy's Avatar
donnie boy
Have you tried cleaning the IACV ? I'm not sure it gives a code.
Old Feb 27, 2009 | 03:46 PM
ASG14's Avatar
ASG14
Is he trying to read the code with a Handheld scanner or by using the diagnostic port in the engine?
Did he try reading the CEL while the light was on?
Old Feb 27, 2009 | 04:47 PM
campoida's Avatar
campoida
Unhappy still looking for problem with no code
He used the port next to the fuses under the steering wheel and the port closer to the pedal (the half round one). with two kinds of hand held scanners. while the light was on and off-cause it does that. within 30 min.
And yes the iacv was cleaned.
Old Feb 27, 2009 | 07:39 PM
ASG14's Avatar
ASG14
Oh, so he did it the right way.
I'd almost think it may be a bad ECU. If the CEL is on, there sould be no reason you can't get the code, except for a bad ECU.
Old Mar 10, 2009 | 03:20 PM
campoida's Avatar
campoida
I went to the local autozone and they got an EGR code. can this cause the car to stall?
Old Mar 10, 2009 | 05:07 PM
esucaris1's Avatar
esucaris1
Yes if the egr is carboned up it can't close during idle and it will run rough or stall...
karan1193
Jan 7, 2015 08:33 PM
diverchris
Dec 27, 2010 07:43 PM
acc
Jun 10, 2010 09:49 PM
Pirates81
RX - 1st Gen (1999-2003)
Sep 14, 2006 03:55 PM
