I have about 2k max to spend. My 95 sc300 cylinder head is about to go and its already had some issues. I got hit in the front drivers side as the picture shows. Already have a headlight from aliga but the fender is still messed up. The paint is not good at all. Is the car worth putting in another GE engine????? What would you guys do on that budget?
GE's are really cheap. You already have a black interior and I don't see the need to part out. Get an engine and fender from aliga. I think youll save more that way
Yea but cosmetically i don't know if it is worth it. Im still debating on what to do....... The 1jz seemed like a good idea but after i would get everything plus installing it, i would be at 3k+
don't waste your time with swaping the motor with a 1jz if you can't afford to spend a possible additional 300 - 500 a month expense on your car don't bother its not worth the headache for you, unless you have a beater so you can drive around while your sc is down and have space for a 3900 lb paperweight
